Accessing Rapid Scada
Forum Home › Forums › Understanding the Software › Accessing Rapid Scada
  • #17261
    123
    If I deploy Rapid Scada on Computer A with a public IP address, and then access it from Computer B using this public IP while Computer A is also accessing it locally, with the two computers being 1000km apart, what issues might occur when both access simultaneously? Could there be any errors during long-term operation?
    If two computers in different locations can access it, can three computers in different locations also access it? Or to put it another way, what is the maximum number of computers that can simultaneously access the Rapid Scada deployed on Computer A?
    #17262
    The number of computers depends on network settings, network redirection, and so on. Network settings do not apply directly to Scada.
    #17263
    There is no software limits. You should control CPU and memory usage, and network traffic of the server.
