關於服務無法啟動 Forum Home › Forums › Questions in Native Languages (Experimental) › Questions in Chinese. 中文问题技术交流 › 關於服務無法啟動 This topic has 9 replies, 3 voices, and was last updated 2 years, 4 months ago by Zeus. Viewing 10 posts - 1 through 10 (of 10 total) Author Posts April 8, 2024 at 11:32 am #14352 catchghostParticipant 启用守护服务: sudo systemctl enable scadaagent6.service sudo systemctl enable scadaserver6.service sudo systemctl enable scadacomm6.service sudo systemctl enable scadaweb6.service 指令輸入後,重開機後還是無法啟動服務 已將文件从文件夹 daemons 复制到 /etc/systemd/system 想請教還缺哪一部分沒有做到嗎? April 8, 2024 at 11:52 am #14357 JWParticipant 能描述一下你的安装过程吗 April 8, 2024 at 12:11 pm #14359 catchghostParticipant https://rapidscada.net/docs/zh/6.0/installation/install-linux 我是依這個安裝程序來安裝 nginx SERVER已啟動,但rapid scada頁面還是無法開啟 April 8, 2024 at 12:22 pm #14361 catchghostParticipant 我以手動安裝的方式安裝 April 8, 2024 at 12:25 pm #14364 JWParticipant 这个中文文档有点旧了,手动安装的文件版本和路径可能有不同。有几点要注意 建议用最新版6.2.1,这版本需要.net8.0,不能用6.0 建议用apt安装.netruntime 8.0,大部分较新的linux发行版都有这个,没有则需要手动添加微软的源 sudo apt-get update && \ sudo apt-get install -y aspnetcore-runtime-8.0 建议用dpkg安装,不需要单独手动操作daemons文件夹和service文件 April 8, 2024 at 12:43 pm #14366 JWParticipant 还有查看log文件的故障描述 /opt/scada/ScadaServer/Log/ScadaServer.log April 9, 2024 at 12:06 am #14369 catchghostParticipant 我已經安裝6.0.了,請問我該怎麼更新到8.0嗎? 我是用手動安裝的 April 9, 2024 at 12:20 am #14370 catchghostParticipant 抱歉我想問的是該怎麼更新到8.0,因為6.0是用手動安裝的 April 9, 2024 at 6:39 am #14371 JWParticipant dotnet runtime 8.0和6.0可以共存的。 如果不行,直接删掉只是手动下载的文件夹和创建的链接即可。 视乎发行版是用apt还是yum,如是ubuntu可直接安装,用以下指令 sudo apt-get update && \ sudo apt-get install -y aspnetcore-runtime-8.0 July 17, 2024 at 1:34 am #14962 ZeusParticipant 确认一下文件的安装路径 Author Posts Viewing 10 posts - 1 through 10 (of 10 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
