Viewing 15 posts - 1,201 through 1,215 (of 6,289 total)
  • in reply to: Current Data sudden become Not Ready #14257
    in reply to: API for Integration #14244
    The above message that does not correspond to the topic of the conversation has been deleted.
    in reply to: Current Data sudden become Not Ready #14242
    It can be a good idea. Please let us know if it helps to solve the issue.
    in reply to: little misunderstanding with the OPCUA Events #14236
    If you provide screenshots from any OPC UA client that does what you need, it can help.
    in reply to: User Input on Table View #14231
    Create a single channel of the Calculated/Output type. Set the Output formula to SetData() After making that settings it should be possible to change channel value by a user. This does not depend on the device.
    If you need to set Modbus register according to a command, configure the Modbus template, and then create channels by a wizard.
    > it is possible to create a Virtual Device
    Yes. In this case, a device just helps to group channels. Calculations are defined by channels.
    in reply to: Current Data sudden become Not Ready #14228
    It seems that we are close to understanding the cause.
    If you restart the PC in usual way, do you get the same error?
    in reply to: Custom Page #14227
    I’ve wrote down a note to increase the priority of this task.
    in reply to: Modbus Data Formula #14226
    > Is there a way for me to define what the event says?
    The answer depends if you use Rapid SCADA 5 or 6. For version 6, set channel properties:
    Input formula would be Cnl > 0 ? 0 : 1
    Format is Off-On
    in reply to: Current Data sudden become Not Ready #14221
    May be the error occurs after the computer restart? And PostgreSQL has not started yet?
    in reply to: Current Data sudden become Not Ready #14220
    1) The error is weird. It’s the first time when we faced this type of error.
    What PostreSQL version do you use?
    2) Probably, it just reconnects. The next time, if the error occurs, try stop and start SCADA-Serve without uploading the project.
    Using pgAdmin simply try to connect to the database and open the data tables after the error occurs.
    in reply to: Custom Page #14219
    Hi Matt,
    Thank you for the reminder.
    Do you need an example that demonstrates how to create an HTML page that uses JS API to get data (like v5 custom page example)?
    in reply to: little misunderstanding with the OPCUA Events #14218
    The OPC UA driver subscribes for data, and receives data in async mode when data comes from the OPC UA server. The driver does not send requests each time to read data.
    > in facts it sends all the cycle data in one event type response.
    Could you copy the example from the communication line log?
    in reply to: How to link the inputs of my device and the tags ? #14217
    OPC DA sometimes unpredictable, unfortunately. While the Rapid SCADA driver uses official .NET OPC libraries, provided by OPC Foundation, they are not ideal.
    Is the OPC server installed on the same machine as Rapid SCADA?
    What OPC server do you use? (just for information)
    in reply to: Read PostGre SQL data and write them in OPC UA #14212
    Please check this video. It should help to connect to OPC UA server. In the video Prosys OPC browser is used. However, any client is OK.
    in reply to: Current Data sudden become Not Ready #14211
    You can see that the error is
    Npgsql.PostgresException (0x80004005): 57P03: the database system is shutting down
    You should check the PostgreSQL database. When it is not available from SCADA, try to connect to it by pgAdmin.
