MikhailModeratorI will recommend OPC UA to our users 🙂
MikhailModeratorYou are welcome )
MikhailModeratorAll required files are located in the folders. So you can install services by executeingsvc_install.bat from command line as administrator.
MikhailModeratorScadaServer generated current data with the millisecond of timestamp are all zero.
What version of MySQL do you use?
Thank you for the solution. I suppose, that the wrong statement is in the queue and never can be skipped.
MikhailModeratorDo you have an idea in which case a sent value is changed to 0, and in which case it is saved correctly?
MikhailModeratorfor the command, you can only make boolean command on/off ?
Command of the Standard type has a value of double type.
Binary command allows sending any data.
MikhailModeratorRapid SCADA works as Modbus master, and it can be TCP server or TCP slave.
I still can’t open tcp connection with Local tcp port 502, error:The network connection was refused by the server.
You can use this Hercules utility to test connection.
MikhailModeratorcommunication line for each port
If I were you, I did this way.
Also possible create a one command line and specify ports for each device in the Call Number field.
MikhailModeratorPlease make screenshots of the following folders
C:\SCADA\ScadaComm
C:\SCADA\ScadaServer
and paste links to them here.If the folders are not empty, execute svc_install.bat from command line as administrator. Make screenshots of the output.
MikhailModeratorIt seems like server executes requests too long. Can you stop the Communicator service and send current data using Server’s Generator?
How many record already contained in the table cnldata ?
MikhailModeratorOK, write here to continue the topic.
MikhailModeratorOf course, sorry ))
Would you create a release of your driver on GitHub to allow others to easily use the driver?
MikhailModeratorHi catcute,
Could you explain the idea what you are going to implement?
Even if you switch operating mode to Slave, the existing Modbus driver works as master. Slave means that Communicator waits for incoming connection, TCP slave (TCP server) not Modbus slave.
MikhailModeratorHow do you integrate node-opcua with .NET?
