Viewing 15 posts - 4,561 through 4,575 (of 6,293 total)
  • in reply to: Events trigger and colors #4504
    Input channels, units that are related to the issue.
    in reply to: Device 11 – Server Room error #4503
    Thank you for updating the status.
    If you share more info about your research, it would be interesting.
    in reply to: OPC write value issue-IBH opc server #4499
    We can connect by Skype to find the solution together. If you OK with it, write me to info@…
    in reply to: Elastic Report Excel Issue #4498
    Could you provide a screenshot of the Excel and PDF reports where the difference is visible?
    in reply to: Events trigger and colors #4497
    See my previous message.
    in reply to: Device 11 – Server Room error #4496
    Did you watch this video and subsequent?
    in reply to: OPC write value issue-IBH opc server #4488
    I am sure that I can write with this method: IOPCSyncIO::Write
    To do this, the OPC driver have to be redesigned using another OPC client library.
    This is possible. However, I suppose that it would be much cheaper if the OPC server developer supports WriteVQT.
    What communication protocol do you use?
    Are there alternative OPC servers?
    Can you find OPC UA server? OPC UA .NET API is officially free.
    in reply to: Events trigger and colors #4485
    Please provide a screenshot of your configuration related to this issue.
    in reply to: Siemens Logo! Modbus #4484
    What recommendations are you referring to?
    First of all, copy here your actual communication log where we can see sending a command.
    If the PLC answer OK, you can:
    1. Compare binary packets with other software that works well.
    2. Contact the manufacturer for support.
    in reply to: Siemens Logo! Modbus #4483
    I ended up going to
    Please don’t mention other products on this forum.
    in reply to: OPC write value issue-IBH opc server #4472
    Try this dll.
    in reply to: Events trigger and colors #4471
    Also, is there a way of recording only one condition of the event?
    Currently no. Some modifications should be done to implement it.
    in reply to: Events trigger and colors #4470
    Event color depends on status color of the input channel. I mean you should change colors of Off-On values.
    Create your own record in the Units table, for example,
    Normal; Alarm; –
    And use formulas for setting the status of the input channel:
    Cnl; Cnl > 0 ? 114 : 13
    in reply to: Siemens Logo! Modbus #4468
    Hennie, you may try the above recommendations.
    in reply to: Create gauge, bar,… #4462
    Read this dialog about building the project.
    You should use the existing components as examples. Gauge and level components already available here.
    Here on the forum I can answer particular technical questions. Be free to ask. Detailed individual lessons are available for a fee.
