May 13, 2019 at 6:42 am in reply to: Difference between current and previous data of same channel #5438
MikhailModeratorLink to the tested formulas to work with previous values.
MikhailModeratorThe image is not in focus. Could you make screenshots by pressing Print Screen button?
You should set channel type to Real.
I suggest the new version to upload configuration easily.
In this year we plan to update Chart Pro. I hope we will include this feature.
Good idea. Thank you.
MikhailModeratorI finished this point.
Could you share how you did it?
MikhailModerator2.if I use automatic control and I set the time, assume I set output ON at 12.00AM and OFF at 12.05AM. Can It show that on the Web page. show something like I set the output ON at 12.00AM and OFF at 12.05AM.
If you need to display time on web page, you should create input channels for storing time, set format to “Time”.
Also create output channels that allows to set the input channels. Use the formula like SetVal(101, EncodeDate(Cmd)) for them. Where 101 is the input channel number.
Also you need input channels that have value 0 or 1. These channels will be used as the triggers in Auto Control Module. And have to compare current time and predefine time.
MikhailModerator1.example. I got the data from registers modbus and I need to show on web page but the data that I got it has to convert to become a decimal number or it dose not real value. so can I use the formula to convert my data before I show it on web.
What value do you get curretnly?
What value do you need to display?
MikhailModeratorHello Juan,
Could you make a sketch?
MikhailModeratorIf you need to update chart plugin according to the custom requirements, we could discuss cost and deadline. In this case please contuct us by email and provide the detailed requirements.
MikhailModeratorMore details about the forumula needed.
MikhailModeratorIt can not detect my alarm condition immediately.
You can, but it’s better to tick “Write events” and “Event on change” checkboxes of the input channel. And you will get events in case of alarms.
MikhailModeratorNice ))
Use formulas to divide raw values.
You should download the plugins and copy their files to your RPi.
Thanks for noticing.
Please take the editor from the new version. This bug was fixed there. -
