Viewing 15 posts - 4,156 through 4,170 (of 6,296 total)
  • in reply to: Modbus TCP Server #5599
    Hi John,
    Sure. Any time. We provide high quality and competitive price 🙂
    in reply to: Auto-update Char #5594
    Do you use the default Chart plugin or Chart Pro?
    What is the version of the chart plugin?
    In browser press F12 and check the Console tab for errors.
    in reply to: Unknown device tags #5591
    Do you know at least a communication protocol? Is it Modbus TCP or other one?
    in reply to: Modbus TCP Server #5587
    Hi John,
    I researched for this, and I have’t found any free solution. We can develop such driver as a custom development by a contract.
    in reply to: Using Multiple VM Computers #5586
    You have 2 options:
    1. Install on RTU VM only Communicator which connects to the Server app of the main VM.
    2. Install on RTU VM full Rapid SCADA and use Rapid Gate.
    about a key that would be needed to use the Rapid Gate. How would this be obtained?
    Buy permanent key or use free trial
    in reply to: Modbus RTU comunication issue #5585
    Seems like hardware problem. What USB-COM converter do you use?
    We have Spanish section in the documentation. It needs to be updated. To work with it, you should register GitHub, fork the repository, make your changes and create a pull request to include them into the project.
    in reply to: New Rapid SCADA 5.7.0 Beta #5577
    in reply to: Modbus RTU comunication issue #5576
    May be other application uses the same port COM4.
    in reply to: Modbus RTU comunication issue #5575
    The log says that there are problems with a converter:
    2019-06-17 17:00:23 Open serial port COM4
    2019-06-17 17:00:23 Error executing the communication channel actions before session with a device: Error opening serial port: Access to the port ‘COM4’ is denied.
    in reply to: Modbus TCP Server #5574
    Rapid SCADA works as TCP client, not TCP server. It connects to a PLC which is TCP server and PLC keeps port 502 open.
    in reply to: Using Multiple VM Computers #5573
    1. Please clarify the question.
    2. Do you mean using real devices or simulators?
    There are 2 videos where shown how to simulate a Modbus RTU and OPC connected device.
    It would be better if you provide a diagram of your system.
    in reply to: Modbus RTU comunication issue #5567
    How the devices are physically connected to Rapid SCADA server?
    in reply to: Error exporting to dB #5563
    I’ve sent an email.
    in reply to: Error exporting to dB #5560
    after about 4 hours a first queue overflow alarm is coming out
    A long time needed for exceeding the queue size means that simple increasing the queue size doesn’t solve the issue.
