MikhailModeratorDo I need to try out the Automatic Control Module to get what I want?
I think you should use formulas.
Do you get correct double value in Communicator?
MikhailModeratorI only need to read 4 registers 5 times a day.
Set the period like written here to poll on time.
MikhailModeratorRoot cause will be clear when the problem is solved.
MikhailModeratorThe provided screenshots don’t contain any error.
Look for communication line log.
MikhailModeratorIt’s possible to develop a native driver, but may be expensive.
Have you directly asked the manufacturer about the OPC?
MikhailModeratorI cannot even get the test project with KpModbus_Adam6015.xml to run. I get “error” instead of normal and communication error.
If you provide screenshots, I will try to help you.
Does my other program polling the PAC3200, powerconfig, have to be offline to communicate?
If you use RS-485, the only one application can poll.
If you use TCP, it depends on a particular device. Many devices support only 1 connection.
MikhailModeratorAfter you do the above, next step is integrating OPC server with SCADA.
MikhailModeratorOPC server is a software developed by a manufacturer of controller.
First, you should download, install it and get data from a device.
If you need support in this process, you should ask developers of OPC server for help.
MikhailModerator
You should try SMA OPC SERVER.
Other option is creating a native driver for Rapid SCADA which interacts with Sunny Webbox directly.
The start question was about another thing.
RPC, JSON and Modbus are completely different.
You should start a new topic and provide the datasheet of your device.
MikhailModeratorIn the properties of communication channel untick the checkbox “Stay connected”.
Increase the timeout and delay parameters of the device.
MikhailModeratorHi Vishnu,
Please post the same log as a text (not image), so I can check it using a tool.
You can find the file in C:\SCADA\ScadaComm\Log
If Windows itself works fast enough, it will be OK for Rapid SCADA.
To be honest, I did this the first time in my life in the simulator.
Likely, addresses are displayed in the left column. The same addresses are specified in the Modbus template in the project. -
