Viewing 15 posts - 241 through 255 (of 6,282 total)
  • in reply to: In terms of usage #17339
    If you are planning to make your derived project open source, Apache License 2.0 have some requirements to the source code. I can provide more details.
    in reply to: In terms of usage #17337
    > 1.Based on your response, am I allowed to change the product name and the product name?
    It is not allowed to change the name of the existing product Rapid SCADA. You are allowed to create a new product based on Rapid SCADA with a new name.
    > 2.Regarding providing information about the original product, can I credit the product’s source in the “About” section of the Main Menu? Does this count as providing information about the original product? If not, please provide a concrete example.
    It should be enough to provide a reference to the original Rapid SCADA in the About page.
    Ask, I’ll be glad to clarify any non-obvious points.
    • This reply was modified 6 months, 2 weeks ago by Mikhail.
    in reply to: In terms of usage #17334
    In short, according to Apache License 2.0 you can create a derived product with a new name, but you have to explicitly provide information about the original product.
    in reply to: How to use PlgChart Plugin #17332
    In the HelloWorld project, PlgChart is active by default. Just click an item in a table view to display a chart.
    in reply to: In terms of usage #17331
    Definitely.
    More info is here
    in reply to: UPC-UA Server Access Control #17325
    A data source configuration file will appear in Communicator – Configuration files, named like DrvDsOpcUaServer.xml.
    in reply to: UPC-UA Server Access Control #17324
    > I guess I would need create multiple UA servers and then set their ports in the xml configs?
    Yes. Click the Properties button to open the data source options. Create a new configuration for for a data source. Find TCP port in the created file. Please let me know about the result.
    > Are you able to explain connection between devices under the communicator vs devices in the configuration database?
    On Server level, there are calculated channels. While on Communicator level, only data received from the devices.
    in reply to: development web plugin-no.1 #17322
    If you ask about installation, file copying is required to ScadaWeb and ScadaAdmin folders.
    in reply to: development web plugin-no.1 #17321
    It’s different. It’s mostly implemented using JavaScript and a bit of C#. See the example here.
    in reply to: UPC-UA Server Access Control #17320
    I suppose, yes.
    Using the Administrator application, in Communicator – Data sources, create several data sources with the DrvDsOpcUaServer driver. Each data source works independently.
    Note that OPC UA server in Rapid SCADA operates on Communicator level. It can access data of Communicator.
    We are planning to implement access to calculated channels on Server level, but it’s in the future.
    in reply to: chartpro issue #17316
    The most likely cause is a change in the computer code due to a change in the computer parameters.
    Please email us a new computer code shown by Chart Pro to check.
    in reply to: how to configure modbus #17315
    I suggest to install Communicator and Agent on the local Linux-based controller to poll the Modbus device. Then configure sending data from Communicator to the cloud server.
    in reply to: manual build Scada, running Scada #17305
    Yes, you right. This is the most optimal way.
    in reply to: How to reset Channel Value on re-boot? #17304
    in reply to: development web plugin-no.1 #17303
    OK
