Viewing 15 posts - 2,071 through 2,085 (of 6,290 total)
  • in reply to: V6 ENUM TEXT and formula at V6 #11910
    Please find enumerations in the Formats table.
    Please advise if the formula was named as script now?
    Yes. This was done to distinguish between channel formulas and general formulas.
    in reply to: Full Documentation Support for V6.0.0 RC #11909
    Any particular due dates may be specified only in a contract. Working on docs for v6 will be started after porting all modules, because we need to know the features of the modules, and make their screenshots for the manuals.
    Documentation for v6 will be at least as full as v5. I hope it will be more detailed.
    in reply to: V6 Format -Enumeration vs string #11908
    I think, using enumeration is better for this case. It is specified in the Formats table.
    in reply to: Remote port number – V6 #11907
    Options to specify communicating with devices are located in configuration of a communication line.
    in reply to: V6 Scheme Editor View ID #11902
    View IDs are specified in the Views table. Probably there is some error occurred. Open the browser console by F12 and check errors.
    in reply to: V584 and V6 at the same computer #11901
    You can install v5 and v6 on the same computer in different locations. But you should stop the services of a one SCADA when another is running, because the services use the same TCP ports.
    in reply to: V6 WebStation #11900
    Language files are located in SCADA\ScadaWeb\lang
    in reply to: Export Table View #11899
    A table view extracts data in exact timestamps. You could configure archives to write data periodically (and on change if needed).
    in reply to: Webstation – localhost #11898
    The installer app creates a new web site that requires port number.
    To use the default port 80:
    Option 1
    In IIS console disable the default web site, and change port number of the Scada site to 80.
    Option 2
    Manually create an application for SCADA within the default web site.
    in reply to: Customization of Scheme titles in browsers #11897
    In case of table views, the title is taken from the Views (Interface) table.
    in reply to: Customization of Scheme titles in browsers #11896
    Set scheme the Title property in the Scheme Editor app when you select a scheme document.
    in reply to: Migrating V5.84 projects to V6 #11895
    There are a lot of differences between v5 and v6 projects. It’s normal to have some questions during conversion.
    in reply to: Migrating V5.84 projects to V6 #11894
    Download the tools from this folder. See ProjConv5to6.zip, HistConv5to6.zip and EventConv5to6.zip
    The project converter archive contains readme.txt
    in reply to: V6 Log – Webstation and Server #11893
    It depends on what application you need to control.
    In case of complex errors, it’s recommended to analyze logs of all applications.
    in reply to: V6 Archieves (minutes/hourly) #11892
    For retrieving raw data from archives, use reports.
