V584 and V6 at the same computer Forum Home › Forums › Understanding the Software › V584 and V6 at the same computer Tagged: V584 and V6 at the same laptop This topic has 1 reply, 2 voices, and was last updated 3 years, 10 months ago by Mikhail. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts January 3, 2023 at 12:05 pm #11868 victorlamParticipant Hello, I would like to test V6 as well as using V584 on the same computer. Do I need to install at two laptop as done now? Or can I install both version V584 and V6 at the same computer? If there is no issues, then I can switch over to V6 directly. At the moment, I need to try one by one before switch over to V6. Please advise the way to install both version and test at the same laptop now. January 5, 2023 at 12:53 pm #11901 MikhailModerator Hello, You can install v5 and v6 on the same computer in different locations. But you should stop the services of a one SCADA when another is running, because the services use the same TCP ports. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
