MikhailModeratorDear Han,
SIM808 replies “ERROR” for message list request.
Did you try to send messages by commands?
Open file as administrator for editing.January 10, 2023 at 1:44 pm in reply to: After several days of running continuously, the rapidSCADA session is denied #11941
The issue happened the 1st time.
Do the OPC servers show active connections? How many connections in total?
What does Rapid SCADA 6 do if an OPC connection is closed by OPC server?
MikhailModeratorThe Arguments cell should be something like “../../custom/MyPage.html”
Path = “Test\test”
Title = “test”
If there is an issue, the error is written in the module log. Could you check C:\SCADA\ScadaServer\Log\ModDbExport*.* ?
MikhailModeratorColumns in the Views table (v6):
Path – path in the explorer, for example, MyFolder\MyPage
View Type = Web page view
Arguments – web page URL
Title – any textIf it does not help, please provide link to a screenshot of the Views table and info from browser console.
Check this document, page 2.
Channel data contains of value and status.
The 1st option generates an event only when value changes.
The 2nd option generates an event when value or status changes.
What user management plugin do you mean? Could you provide a screenshot?
Can I use this notification management plug in temporarily
Currently, there is no Notification Plugin for v6.
Please find plugin descriptions in the Administrator application.
There is no Notification Plugin for v6.
To acknowledge an event, click the ack checkbox in the event panel in the bottom of the page.
Not all events can be acknowledged. It depends on event severity.
Could you provide error details?
all the configuration and set up must be done via Administrator
Yes. This approach helps to avoid loosing the configuration changes.
including the previous plug in authorization
Which plugin do you mean?
When we develop Notification Plugin for v6, you can upgrade the key for the same computer for which you bought the key.
