Viewing 15 posts - 1,546 through 1,560 (of 6,289 total)
  • in reply to: ModDbExport Questions #13312
    Screenshots should be available online. Use image hosting like https://imgbb.com/
    in reply to: Events and Ack #13311
    Can you put this in the wish list?
    Added.
    Where I can view the progress of the wish list?
    The wish list is internal. Roadmap is available, but it is not detailed.
    The feature implementation is possible only after we create a new generation of scheme engine. To be honest, not soon.
    in reply to: Dependicies failed to load #13309
    Also check that ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll is also unblocked.
    Note: ScadaWeb and ScadaSchemeEditor uses different PlgSchExtraComp.dll.
    • This reply was modified 2 years, 9 months ago by Mikhail.
    in reply to: Dependicies failed to load #13308
    Make sure that you downloaded the latest version of components (plg_sch_extra_comp_6.0.1.0_en.zip) which contains ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll
    in reply to: How to use it on ubuntu #13307
    The Administrator application should be installed on Windows. It interacts with Rapid SCADA instance, which is installed on Linux, remotely. You should add a new deployment profile in Administrator for remote connection.
    in reply to: Events and Ack #13300
    JavaScript API allows to request events. However, this approach requires development of a component that implements this feature. We could help you to develop such component, or can add this feature to the wish list.
    in reply to: ModDbExport Questions #13298
    Please provide links to the screenshots of the settings.
    What is the DB Export module version?
    in reply to: OPC DA null values because bad quality. #13297
    Note: The Automatically accept certificates checkbox should be unset in production environment. I’m not sure, may be the driver stores a certificate into the storage after it is accepted. Otherwise, it should be copied manually.
    in reply to: Unable to cast COM object of type ‘System.__ComObject’ #13296
    This topic is useful to avoid such mistake. Let it be.
    in reply to: How to use a c# script to process input XML/MQTT message #13295
    1. Add your scripts into the Scripts (v6) or Formulas (v5) table.
    2. Write a DLL in C# using the examples from GitHub.
    3. The MQTT driver support JavaScript.
    Please specify your question.
    in reply to: 如何在ubuntu上使用 #13294
    In Chinese please write in this subforum. Or use English.
    in reply to: OPC DA null values because bad quality. #13286
    I did the following test:
    1. Use the default settings of the OPC UA Server data source. The Automatically accept certificates checkbox in set.
    2. Install and run Prosys OPC UA Browser.
    3. In Prosys OPC UA Browser
    – Security settings: Sign, Basic256Sha256
    – User auth: username and password (opc / scada)
    4. When connect, the client asks to accept the certicicate.
    5. Connected successfully.
    Note: the same machine for client and server.
    Could you repeat this test?
    in reply to: Events and Ack #13281
    If you need to check all existing events associated with a channel, it’s possible, but may slow down the performance.
    in reply to: Events and Ack #13280
    You can load an event by ID and check the Ack field.
    Do you use Rapid SCADA 5 or 6?
    in reply to: OPC DA null values because bad quality. #13276
    I can check this issue the next week.
