Dependicies failed to load
Forum Home › Forums › Installation Issues › Dependicies failed to load
  • #13303
    DHague
    I am trying to use “Extra Scheme Components” to make better schemes. However, after following the guide (copied it into the SCADA folder, unblocked the dll, activated, registered with trial license) it gives me this error in the logs.
    2023-09-05 14:55:12 <RAPIDSCADAVM><Administrator><ACT> Initialize common data of Scheme Editor
    2023-09-05 14:55:12 <RAPIDSCADAVM><Administrator><ACT> Load components from files
    2023-09-05 14:55:12 <RAPIDSCADAVM><Administrator><ACT> Components are loaded from the file C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchBasicComp.dll
    2023-09-05 14:55:12 <RAPIDSCADAVM><Administrator><ERR> Error loading the plugin assembly C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll:
    Could not load file or assembly 'file:///C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
    2023-09-05 14:55:12 <RAPIDSCADAVM><Administrator><ACT> WCF service is started
    2023-09-05 14:55:26 <RAPIDSCADAVM><Administrator><ACT> WCF service is stopped
    2023-09-05 14:55:26 <RAPIDSCADAVM><Administrator><ACT> Scheme Editor is shutdown
    If someone could tell me what dependencies I need, that would be great, thanks.
    #13308
    Make sure that you downloaded the latest version of components (plg_sch_extra_comp_6.0.1.0_en.zip) which contains ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll
    #13309
    Also check that ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll is also unblocked.
    Note: ScadaWeb and ScadaSchemeEditor uses different PlgSchExtraComp.dll.
    • This reply was modified 3 years, 2 months ago by Mikhail.
