MikhailModeratorYou need an additional variable to store a flag that the condition change has already processed. After adding 1, set the flag ON. When the condition becomes false, set the flag to OFF. The formula is not very simple, because it executes in a loop as written above.
Alternatively, you could increase a channel inside the formula of the condition if it’s applicable.
September 14, 2023 at 10:51 am in reply to: How to use a c# script to process input XML/MQTT message #13372
MikhailModeratorSeptember 14, 2023 at 10:50 am in reply to: How to use a c# script to process input XML/MQTT message #13371
MikhailModeratorAlso you need to specify subitems.
September 14, 2023 at 10:49 am in reply to: How to use a c# script to process input XML/MQTT message #13370
If you need to use JS to extract values from JSON, set JavaScript enabled = Yes (in device properties). Create a js file, put it in the Communicator configuration. Specify the file name in the JavaScript file name property.
MikhailModeratorPlease create a new topic to discuss configuration of the Dashboard plugin. Provide links to screenshots of your settings.
MikhailModeratorYou should download the plugin from the website, install and try it. Example of plugin configuration is included in the distributive ZIP. In case of additional questions, ask on this forum.
September 13, 2023 at 8:46 am in reply to: How to use a c# script to process input XML/MQTT message #13355
MikhailModeratoris there any documentation that I can have a look to understand scripts and the way it works
Currently, only the forum. The docs should be created, of course.
September 13, 2023 at 8:45 am in reply to: How to use a c# script to process input XML/MQTT message #13354
MikhailModeratorYou need to create a communication line in Communicator. Then choose MQTT Client as communication channel type. Then create a device under the line, open its properties and specify subscriptions.
September 13, 2023 at 8:43 am in reply to: How to use a c# script to process input XML/MQTT message #13353
MikhailModerator
MikhailModeratorThis new article https://rapidscada.net/docs/en/latest/installation/install-modules describes how to install plugins on v6.
MikhailModeratorTo manually write data to archives, use the ScadaTestClient utility.
Please write questions of different areas in different topics having corresponding titles. Otherwise it’s too difficult to reply.
September 11, 2023 at 9:19 am in reply to: Modbus TCP – Start Element Address (DEC) Communicator v.5 vs Latest v.6 #13330
MikhailModeratorNote: you can simply copy the XML file of the Modbus template from the old project to the new one. Then open the template in Administrator, change something, and save again to update file format.
September 11, 2023 at 9:18 am in reply to: Modbus TCP – Start Element Address (DEC) Communicator v.5 vs Latest v.6 #13329
MikhailModeratorClick the Options button (gear) and switch addressing.
September 11, 2023 at 9:17 am in reply to: Cannot Access http://RapidScadaIP:10008 from Other Computers in LAN #13327
MikhailModeratorThank you for providing the cause of the issue.
MikhailModerator> finally discovered that the “join” between the “channel” definition is the matching “tag code” in the communicator module.
Right.> How can one manipulate the historical data in a similar fashion to the previous Rapid SCADA versions?
Rapid SCADA 6 supports different storages, so archives can be viewed in the web interface (reports) and ScadaTestClient-v6.zip> there seems to be no “Save” button when editing the objects in the Scada “Administrator” application
It’s not changed. -
