Viewing 15 posts - 1,246 through 1,260 (of 6,282 total)
  • in reply to: Formula lowestValue #14107
    There is a ready to use DayStarted() function. It equals to true in the beginning of the day. Probably, using this function inside your formulas can fix the issue.
    If you provide screenshots of your channels, I can check them.
    in reply to: Uploading Product Recipe files #14106
    Thank you for the description.
    It is possible to develop a plugin that provides a web page that uploads a file and save it somewhere on the server side if it solves your task. It can be done by a .NET developer. Be careful, because uploaded files may harm the system if it is available from the global internet.
    in reply to: How to use EveryPeriod Function? #14105
    Probably, it’s better to create your own function that uses the EveryPeriod method.
    execSpan can be equal to period / 10
    in reply to: How to use EveryPeriod Function? #14104
    EveryPeriod is defined as protected. You can change it to public and try using it directly. The period argument would be taken from a channel value, for example.
    The execSpan parameter provides a flexible period when getDataFunc can be executed. Note that EveryPeriod is called many times a second by the Server engine, and you don’t know the particular moment when it is called.
    Thank you for describing the solution.
    Note that you can use TCPView utility to find what application uses a port.
    in reply to: How to install Rapid SCADA on ubuntu server ? #14101
    If you need help, please provide errors you got.
    Yes, we plan to provide a video for a Linux installation, but I don’t know when.
    in reply to: Elastic Report – formulas #14091
    Formulas that calculate totals are predefined. Unfortunately, you can’t calculate only negative values in the described case.
    However, a section of the DataData type can contain a custom formula. May be you can use a custom formula in the DataData section that refers the previous TimeData section.
    Note: Elastic Report formulas work only in Excel format.
    Note2: Elastic Report 6 supports XLSX format instead of Office XML 2003.
    in reply to: Uploading Product Recipe files #14090
    To upload a file, a plugin should be developed.
    If the recipe file is uploaded, how it will be executed?
    in reply to: How to use ModArcPostgreSql? #14087
    Try the new module ModDiffCalculator. The configuration example is included in the archive. The module is compatible with Rapid SCADA 6.2.x. In case of questions, create a new topic.
    in reply to: How to use ModArcPostgreSql? #14086
    Yes, the rapid_scada database should be created manually.
    Thank you for the update.
    in reply to: Flux is entered maintenance mode #14083
    If InfluxDB3 does not support Flux, ModArcInfluxDb.dll will require full rewrite.
    in reply to: Flux is entered maintenance mode #14082
    I suppose, they will provide backward compatibility and we can use Flux for a long period. We should wait until they found a good solution. Who knows, may be in InfluxDB4 they will change the approach again.
    in reply to: Current Data sudden become Not Ready #14081
    OK. Save log files in case of error.
    in reply to: Flux is entered maintenance mode #14078
    Do you use InfluxDB with Rapid SCADA?
    in reply to: Flux is entered maintenance mode #14077
    Thank you. That is interesting. I guess, InfluxDB will go through a period of instability because of so significant changes.
