Viewing 15 posts - 736 through 750 (of 6,221 total)
  • in reply to: Rest API client communication #15501
    No. The request format should be as you posted.
    in reply to: Utility Pack 6.0 Instructions #15499
    We just want to have daily backup in easily accessible format.
    Good idea. It can be used in a combination with other backup methods.
    in reply to: Utility Pack 6.0 Instructions #15496
    will there be any changes in script to convert while generating data?
    There are no such plans. We might add a time zone option for a fee.
    I would like to understand for what purposes you export data to CSV?
    in reply to: Auto Report #15495
    > My understanding is to have it in XLSX format I need Elastic addon?
    XML format of the reports is Office XML 2003 that can be opened by Excel and Libre Office.
    Elastic Report can generate reports in XLSX format.
    I hope we will support XLSX for the default reports someday.
    in reply to: I have issue about database import (MYSQL) #15493
    Set Data type to empty for all channels except 103.
    Set Format for the channel 102
    in reply to: Rapid scada data streaming API #15487
    Please create a corresponding topic to discuss DrvMqttPublisher.
    in reply to: Auto Report #15486
    In case of concerns, provide screenshots of the AutoReport settings.
    in reply to: Auto Report #15484
    As there is no video or detailed manual for Auto Report installation I have stuck on testing it on version 6.
    Feel free to ask here. I hope we will create videos to cover the most of questions in the future.
    Create a device and an output channel to send and receive commands for generating reports.
    It’s not needed. AutoReport is a separate service that has it’s own schedule to run reporting tasks.
    • This reply was modified 1 year, 6 months ago by Mikhail.
    in reply to: Utility Pack 6.0 Instructions #15483
    Were you able to obtain the data using the bit number?
    in reply to: I want to display text from decimal numbers. #15478
    Data polling seems OK.
    I recommend:
    1. Use Rapid SCADA 6, because Rapid SCADA 5 is outdated.
    2. Provide names for the elements in the Modbus template.
    3. Create a simple table view to check data displaying. Then create a scheme view.
    in reply to: Rapid scada data streaming API #15477
    Yes.
    in reply to: Utility Pack 6.0 Instructions #15476
    The Minute archive has bit 1.
    See https://ibb.co/jv7HS8J
    The configuration database is available for a module view. Check this source code.
    in reply to: Rapid scada data streaming API #15471
    Probably, you need both.
    in reply to: Dynamic marker’s color using the Map plugin #15470
    In the current version of Map Plugin the status colors are predefined.
    It can be a good idea to implement more colors in the future versions of the plugin.
