MikhailModeratorHi Bret,
Great, you guessed it ) In the new version of SCADA-Communicator device driver DLL is independent of a connection type. Special software layer named Connection channel establishes and manages the connection.
You tuned up SCADA-Communicator almost correct, but in your case you shouldn’t define IP address in the properties of the connection channel. Do it in Call Number field of a device like before.
You definitely right.
After configuring using Windows you should copy the content of the follownig folders:
C:\SCADA\BaseDAT
C:\SCADA\Interface
C:\SCADA\ScadaComm\Config
Did you install Rapid SCADA 4 Release 4?
Please, describe the sequence of your installation and upgrade steps.
I think, the reason of the issue is listed in the main log of Communicator C:\SCADA\ScadaComm\Log\ScadaCommSvc.log
MikhailModeratorOK, no problem )
At the current time, Rapid SCADA supports only OPC DA and OPC AE specifications.
If Cewe provides its own utility that request devices, we can sniff data exchange and realize what should we do.
First, download and install the full package. Then download http://rapidscada.org/download/scada_4.5_update.zip and overwrite files in C:\SCADA\ScadaComm folder. If you find any bugs, post them in a separate topic.
MikhailModeratorWhen you click an icon in a table view, a chart will be shown.
The same effect if you set Action property of a scheme element to “Draw diagram”.Component for Charting has additional functions such as scaling, displaying of multiple charts and choosing the period (v4.5+).
September 3, 2015 at 10:54 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #398
MikhailModeratoradmin / 12345
guest / 12345
What are you going to do?
Every device supports its own application layer protocol via TCP/IP. For example, Modbus TCP which is the most popular.
September 2, 2015 at 6:30 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #391
MikhailModeratorHello Dejan,
Thanks for the info.
In addition, if IIS was installed after .NET, it is required to integrate them by executing aspnet_regiis.exe -i
MikhailModeratorI think, it works as expected.
Export current data error occurs because you send the same data twice.
Export archive data is executed, for example, when you select Generator in SCADA-Server and send archive data.Current and historical data are stored in the same data table in case of using SQL from the manual.
September 1, 2015 at 2:48 pm in reply to: Rapid Scada not running on Web Browser due to 404 not found error #386
MikhailModeratorDejan,
Your Windows Features screenshot seems OK.
What is the error page at the current time? -
