Viewing 15 posts - 601 through 615 (of 6,288 total)
  • in reply to: DrvParserTextJP #16236
    Thank you 🙂
    in reply to: Web Station Error 500 #16231
    I keep seeing in the log that the Webstation is stopped. Now what?
    This is a normal behavior. If the web application has not been used for some time, it is stopped. When you open it again, it will be started. You can see than in the log file.
    in reply to: Web Station Error 500 #16230
    How can I totally uninstall the program and servers so that I can install it again?
    Usually it’s reinstallation needed to fix an issue.
    Website with the same name exists and Application pool item already exists.
    How so I deal with this, please?
    You can delete the pool and website manually in the IIS management console. If you are not sure, provide screenshots.
    in reply to: The page transitions are slow #16229
    Could you provide a screenshot or video?
    in reply to: Web Station Error 500 #16223
    Check the above.
    in reply to: Average value from 5 last values #16222
    May be you should set an input formula of the channel 145 to blank, and try again.
    in reply to: Average value from 5 last values #16218
    If you remove Val(145) in that channel, where do you set the channel’s 145 value? Which place the TimeUpdate() function is called?
    in reply to: Send values and commands #16216
    The Format field affects a command sending dialog. Could you make a screenshot of the command dialog?
    in reply to: Send values and commands #16215
    Have you tried the Toggle component?
    A draft of UI element may help to understand the question more precisely.
    in reply to: how to modify the string through send command. #16212
    The function below takes a data length into account for Unicode strings.
    public byte[] SetUnicode()
      if (ArrIdx == 0)
        string s = CmdData == null ? "null" : Encoding.UTF8.GetString(CmdData);
        int dataSize = Channel.DataLen ?? 1;
        for (int i = 0; i < dataSize; i++)
          string part = Substring(s, i * 4, 4);
          SetData(CnlNum + i, EncodeUnicode(part), 1);
      return CmdData;
    in reply to: Average value from 5 last values #16211
    It seems that using the Val(145) input formula in the channel 145 is excessive.
    in reply to: how to modify the string through send command. #16208
    Add the following function in the Scripts table:
    public byte[] SetStr()
      string s;
      if (CmdData == null)
        s = "null";
      else
        s = Encoding.UTF8.GetString(CmdData);
      SetData(CnlNum, EncodeAscii(s), 1);
      return CmdData;
    Set the output formula of the channel to SetStr()
    It works for a channel of the data length = 1 (or empty)
    in reply to: Show Rapid SCADA Version #16207
    In general, I suggest to download and save locally Rapid SCADA package and all plugins at the same moment to ensure they are compatible.
    in reply to: Show Rapid SCADA Version #16206
    HOW does one determine/show what version of Rapid SCADA is currently installed?
    Rapid SCADA of version X.X.X consists of several applications. Each application has its own version Y.Y.Y.Y. You can find versions of any certain application in the UI or logs. Then search in the product history to realize which Rapid SCADA version matches. However, an application may be unchanged and included in a few versions of the distributive.
    Thanks.
    in reply to: Average value from 5 last values #16205
    Formulas for rolling average are here.
