Viewing 15 posts - 586 through 600 (of 6,288 total)
  • in reply to: Tagging Asset using SCADA #16278
    Could you clarify the question?
    in reply to: Not getting to view as a web page #16277
    In ScadaServer.log, there is no connection made by the ScadaWeb user. It looks like the web application tries to connect to another TCP port. Open the connection options of the Webstation app using the Administrator app and check that the port 10000 is set there.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16270
    Make sure that the latest updates are installed on your Windows 11.
    in reply to: Not getting to view as a web page #16269
    Using the TcpView utility make sure that TCP port 10000 is not being used by any other application except the ScadaServer service.
    in reply to: Not getting to view as a web page #16268
    Please also provide ScadaServer.log
    in reply to: schemeeditor doesn’t launch at all – windows11 #16267
    Thank you for the info.
    Scada.Scheme.Editor.AppData.StartWcfService(System.String ByRef)
    The above line means that the error occurred when starting a WCF service.
    This discussion is related to the issue, but it does not contain a solution.
    We are planning to get rid of WCF in Scheme Editor. Until then, I suggest using a virtual machine to create schemes.
    in reply to: Not getting to view as a web page #16264
    Access to the log files is denied. Please make them public.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16263
    I see under the “Instance Status” it says webstation “Status not supported” Can it be relevant?
    It’s not relevant. It just means that the app does not provide status.
    I suggest to check events in Windows Event Viewer. If an app accidentally crashes, the OS writes some info there.
    Also try to deploy a new virtual machine using Hyper-V or VMware and install the editor from scratch.
    in reply to: Not getting to view as a web page #16259
    Please provide a screenshot of the error by posting a link to Google Drive or other image hosting.
    Also check the ScadaWeb.log and ScadaServer.log files.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16258
    When the editor starts correctly, ScadaSchemeEditor.log contains
    2025-03-25 12:50:42 <PC><user><ACT> Initialize common data of Scheme Editor
    2025-03-25 12:50:42 <PC><user><ACT> Load components from files
    2025-03-25 12:50:42 <PC><user><ACT> Components are loaded from the file C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchBasicComp.dll
    2025-03-25 12:50:43 <PC><user><ACT> WCF service is started
    The editor uses WCF, so you may need to enable it as shown here.
    The editor opens TCP port 10001. Using TcpView make sure that the port 10001 is not used by another application.
    in reply to: Webstation issues on Win11 #16255
    When an error occurs, the details are written in ScadaWeb.log. Please check the log file for additional info.
    in reply to: Webstation issues on Win11 #16253
    ScadaWeb.log is OK.
    Errors like “Dictionary file not found” are not critical.
    What do you get when open http://localhost:10008/ in browser?
    Would you be able to explain the process of how the data from the Communication lines is transferred to the WebStation?
    The Webstation app connects to the Server app using TCP port 10000 and requests data.
    in reply to: Webstation issues on Win11 #16248
    Screenshots of the settings and results would help to solve the issue.
    in reply to: DrvParserTextJP #16247
    The driver has been added to Store
    https://rapidscada.net/store/Module/en/DrvParserTextJP
    in reply to: Table View Invalid DateTime Error #16238
    Please open the browser tools (F12), select the Network tab, and make screenshots of the HTTP request details.
