MikhailModeratorSend me, please, an email request for price estimation. Also attach full description of the communication protocol.
Email address is here
MikhailModeratorYou need to develop by yourself or purchase development of a device driver.
Read Device Drivers Development
Source code examples are here
MikhailModeratorWhat communication protocol is supported by the device?
MikhailModeratorI didn’t write: you have to change channel type to Calculated real.
MikhailModeratorI mean that you should enter the whole CheckTime() function in Formulas table. Then enter just CheckTime() in Input channels table.
MikhailModeratorThe simple formula example:
double CheckTime() { DateTime nowDT = DateTime.Now; return nowDT.Hour == 1 && nowDT.Minute == 0 ? 1 : 0; }
MikhailModeratorDo you need a special time for sending command or just a period of doing it?
How accurately you need to define a time? Is it enough to set hour only or hour and minutes?
MikhailModeratorIn this case you should use another approach:
Create an input channel as a flag and check time in the channel’s formula. Then create a trigger that fires on the flag value.
To change the timer counter according to a command you need an output channel.
Please describe your task in details. Why do you need it?
MikhailModerator10 min after start Server service. What is in the module log?
MikhailModeratorThe default password is 12345. Try to enter it and look 🙂
Go to Commands tab in Communicator and send a command with a number specified in the template. You should see the command in communication line log and in Device Data tab.
If it works, configure output channels, bind them to a scheme or a table view and send via the web app.
All the forces are aimed for the development of the new web app. You could use both versions simultaneously while it is not fully ready.
MikhailModeratorHi!
Chart Pro and Chart List components will be implemented for the new web app within a few months. Probably, they will require new keys, but in case that you already have a license, the new keys will be free for you. -
