Viewing 15 posts - 5,626 through 5,640 (of 6,289 total)
  • in reply to: SCADA – communicator – unable to browse #1670
    Also you can add items to the configuration file manually and watch whether it works or not.
    File path: C:\SCADA\ScadaComm\Config\KpOpc_XXX.xml
    in reply to: SCADA – communicator – unable to browse #1669
    There are few similar questions:
    1st
    2nd
    3rd
    I think, you should try tuning DCOM configuration. How to open the config is described at the end of the article.
    in reply to: Display of current data value #1668
    Please, provide your value of the formula field of the input channel.
    in reply to: SCADA – communicator – unable to browse #1665
    Does this error appear for any folder of the OPC server?
    Could you try the same with Matrikon.OPC.Simulation server?
    in reply to: I need to read data format RTU modbus INT32-M10K #1664
    Does it work for the current time?
    in reply to: I need to read data format RTU modbus INT32-M10K #1660
    The approach is
    1. Receive data in UInt16 (4 Bytes)
    2. Create a formula in the configuration database (SCADA-Administrator, Formulas table) which decodes the data.
    3. Use the formula for your input channels in the Formula field.
    Do you have an algorithm how to convert INT32-M10K to normal integers or floats?
    in reply to: Display of current data value #1658
    1. Create a formula in the Formulas table:
    int CorrectStat()
      return CnlStat == 5 ? 0 : CnlStat;
    2. Add the expression in the Formula field of an input channel:
    Cnl; CorrectStat()
    Note: I didn’t test this answer. It should work, but may have mistakes.
    • This reply was modified 9 years, 8 months ago by Mikhail.
    in reply to: Display of current data value #1654
    Good idea, thank you.
    I’ve added it to the issue list.
    If it is critical to your project, it is possible to change the Unreliable status to Undefined by a formula of input channel.
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1651
    You can create special files. Try to stop SCADA-Server then send commands using Communicator. You can see the files in C:\SCADA\ScadaComm\Cmd
    There is an example how to do it.
    in reply to: Display of current data value #1649
    If Communicator is off, the values become undefined in 5 minutes by default. You can change this time span by the parameter “Unreliable on inactivity” in SCADA-Server.
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1648
    In this case you can use SendStandardCommand, SendBinaryCommand and SendRequestCommand methods which establish TCP connection with SCADA-Server. Why you need non-TCP way of sending commands?
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1645
    Could you provide more details or example of the situation?
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1643
    It is an ID of a user from the configuration database which you can see in Administrator. You can set it to 0 means undefined. User ID is just an information who send a command.
    in reply to: optimum system requirement #1641
    Probably, the first list item above is difficult to implement, because devices are installed for a long period of time. In this case you need a software simulator of devices, that can respond for requests.
    in reply to: optimum system requirement #1640
    polling frequency 30 sec to 5 mins distributed among devices
    This is not high load.
    1. After you configure Rapid SCADA, you should start the whole process and watch for CPU, RAM, HDD and network load.
    2. Test responsiveness of the web app by serfing data views. Compare first open time of a view if Communicator is running or not. First open time after restart application pool of IIS.
    3. Explore logs of the web app and SCADA-Server service (you should switch to detailed log).
