optimum system requirement
Forum Home › Forums › Installation Issues › optimum system requirement
  • #1577
    medvdev
    Dear Sir,
    Can you suggest some server configuration (system requirement), so as to establish a robust and statble server, I mean will it work better with windows based system like win 10 or with windows server editions, or linux based system , have you tested the most stable configuration.
    Regards,
    #1581
    The most tested OS with Rapid SCADA is Windows. I recommend Windows Server 2012 R2 in case of industrial application. If your system is small, Windows 10 is enough.
    How many input signals and active users is planned?
    #1635
    derinder
    Hello there,
    So far set up looks gud…
    We are planning to test this software ….
    so far it is working gud with small set up of 3-4 devices…
    will it be equally good with, large set up of say , 1000 devices with about 15000 (input +output) signals.???
    what would be server requirement then..?? (CPU+RAM)
    any suggestion? for about 10 active clints (web user).
    #1636
    Rapid SCADA is tested in the lab with 10000 input channels and works well on Pentium i3 and 4GB RAM. Active communication between Server and Communicator may require more resources.
    Some additional questions:
    1. What OS is planned?
    2. What frequency of polling is really needed?
    #1637
    derinder
    Hello Mikhail,
    Considering other fourum query.. please comment on following configuration:-
    1) Windows Server 2012 R2. (I think server 2016 is better have you test it??)
    2) Intel i5 quad core 3Ghz or higher.
    3) 16 GB or higher RAM.
    4) 1 TB HDD.
    5) Frequency of polling :- ( not actually decided yet) any optimum suggestion from your side as per system capability??? How much you think it can handle…??
    Regards,
    #1638
    1) Both are good choice.
    Server 2016 is not tested with Rapid SCADA, but I’m sure, it will work well. In case of any issues with it, I can help you.
    2-4) Very good.
    5) I forget to ask about communication protocols. Could you describe how devices will be connected?
    I think, from 10 to 100 parallel polling threads (communication lines) have to work.
    It would be wonderful if you share stats when you launch the system.
    I recommend Extended Support for important systems. Also recommend the new web app.
    #1639
    derinder
    Hello ,
    5) communication protocol will be through TCP gateways.
    —> Nothing is finalyse yet… still we are exploring the available options… mean while i am trying to test the stability and reliability and capability of rapid scada…
    —-> As one single communication line can communicate with say up to 25 devices… (polling frequency 30 sec to 5 mins distributed among devices) I think up to 90 communication lines may be used… some lines will be loaded with less number of devices.
    —-> please explain your last point…
    “I think, from 10 to 100 parallel polling threads (communication lines) have to work.
    It would be wonderful if you share stats when you launch the system”
    How loading is determined on your system…. It will be on TCP protocol.(via TCP gateway)
    Regards,
    #1640
    This is not high load.
    1. After you configure Rapid SCADA, you should start the whole process and watch for CPU, RAM, HDD and network load.
    2. Test responsiveness of the web app by serfing data views. Compare first open time of a view if Communicator is running or not. First open time after restart application pool of IIS.
    3. Explore logs of the web app and SCADA-Server service (you should switch to detailed log).
    #1641
    Probably, the first list item above is difficult to implement, because devices are installed for a long period of time. In this case you need a software simulator of devices, that can respond for requests.
