Viewing 15 posts - 5,581 through 5,595 (of 6,289 total)
  • in reply to: rapid scada5.0 installation and page #1777
    Please create a separate topic in Understanding the Software subforum.
    in reply to: rapid scada5.0 installation and page #1775
    IE is outdated.
    Use Chrome, Firefox or Edge.
    when i upload my pictures,it often show that the web page can not be found,why?
    I can’t reproduce this problem. You can try any other image hosting.
    in reply to: rapid scada5.0 installation and page #1769
    Installation issues:
    I suppose you did a few attempts to install. So ScadaServerService and ScadaCommService are already exist in the system.
    Web:
    What browser do you use?
    in reply to: rapid scada5.0 installation and page #1764
    1. Go to http://postimage.org
    2. Upload your image
    3. Copy the link in the forum.
    Also you can provide a link to a screenshot hosted on any public file hosting such as Google Drive or Dropbox.
    in reply to: rapid scada5.0 installation and page #1762
    it is the rapid scada 5.o,but it miss the sadaweb configuration,why?
    See this answer.
    when I uninstall the rapidscada 4.5,then I install the 5.0,it shows two faults.why?on they are scada commnication and service has been completed with the eror
    Please provide screenshots or log text of the errors.
    when i install the 5.0 and login in, i cannot look the views and table,why?
    Please provide a screenshot.
    Use postimage.org or similar hosting to post screenshots. Insert image links into your messages.
    in reply to: FS20 and FHZ #1760
    It’s better to provide links to the manuals.
    in reply to: New database #1758
    in reply to: New database #1756
    Which additional modules should I by and how can I display self made charts and displays.
    This is the standard functionality which doesn’t require commercial modules.
    I recommend Chart Pro Plugin for advanced charting. It is optional.
    in reply to: New database #1755
    2. Create a view using Table Editor or Scheme Editor. Save it into C:\SCADA\Interface
    Then define a view in the configuration database in the Interface table using SCADA-Administrator. Use the default views as an example.
    In case of follow up question be free to ask.
    in reply to: New database #1754
    1. To delete the default data, start from the Rights table and go to top to the Object table. Click the Clear table button to delete all the rows of the table.
    Do not delete roles with IDs from 1 to 4.
    Do not delete users with IDs from 1 to 3.
    Do not delete data from the dictionary tables.
    • This reply was modified 9 years, 7 months ago by Mikhail.
    in reply to: Access SCADA-web configurator #1749
    Create a new topic and provide the details of the issue.
    in reply to: Diagramms #1747
    For now, levels can be displayed by a dynamic image component. You should create a set of images, for example for 0, 10%, 20%…100% and switch them according to an input channel value. See uKon project here.
    In the future we are planning to develop a control which will display such level.
    in reply to: Access SCADA-web configurator #1744
    Oh, the manual a bit outdated. The windows application SCADA-Web Configurator was transformed to a web page.
    in reply to: Access SCADA-web configurator #1742
    The active plugins are already started. If you deactivate them, you will see that some menu items or views disappear.
    For example, if the menu item “Main Menu > Configuration > Web application” is visible, it means that Config plugin works.
    in reply to: Diagramms #1739
    Could you provide screenshots or examples?
