I suggest also test in a table view.
The above advice should work.
If a channel has a length = 5, it is internally 5 channels. A formula is executed for each of them.
MikhailModeratorIt would be useful to develop an OPC UA server for Rapid SCADA on the level of the Server service (in addition to the existing OPC UA server for Communicator), so it can provide calculated values.
While waiting for the example, this video about Modbus may be useful.
REST API is provided by the web application of Rapid SCADA. Take a look at this topic.May 27, 2025 at 11:08 am in reply to: How to create OPC DA client connecting with OPC DA server start with Windows #16423
MikhailModeratorDear Hatien,
It’s possible that the OPC server starts later than the Communicator service, and causes communication issues.
Try changing the properties of the ScadaComm6 service to delay before start.
Alternatively, restart the communication line manually or automatically if there is no connection with the OPC server.-
This reply was modified 1 year ago by
It seems like this issue appeared many years ago and was fixed. I suggest to upgrade Rapid SCADA to version 6.May 26, 2025 at 11:08 am in reply to: How to create OPC DA client connecting with OPC DA server start with Windows #16419
If you restart an OPC DA communication line (using the Administrator app), does a connection repair?
This topic is related to Modbus. Please ask about MQTT in a proper topic.
Rapid SCADA supports both Modbus and MQTT. Device polling is configured manually. If it’s needed to automatically recognize new devices, you should develop some additional module for Rapid SCADA.
Lora is a very common name. You should check the documentation of your Lora gateway and find information how it can provide data for the SCADA software. May be it can work in transparent mode so you could receive data in Modbus format.
MikhailModeratorI’ve added that feature to the backlog.
Do you mean that channels should be searched recursively under a parent object?
You can try to build and activate 2 plugins: PlgMimic and PlgMimicEditor. But they are on early stage.
When they are ready enough, I will publish a demo.-
This reply was modified 1 year, 1 month ago by
MikhailModeratorYou could try to insert an Elastic Report in HTML format as a web page view.
It will display what you need, but without automatic refresh.-
> When the channel value is 0, the channel will not be displayed in the table.
Table view cannot switch channel displaying.
In a scheme view, it’s possible to change an image depending on channel value, so it will solve the question for discrete channels. -
