Viewing 15 posts - 5,221 through 5,235 (of 6,290 total)
  • in reply to: Chart Pro Y Axis scaling #2736
    I sent an email.
    in reply to: Dashboard Chart #2735
    Thank you for the link. It’s better than a screenshot.
    Try http://fischerp.selfhost.eu:8888/Scada/View.aspx?viewID=2
    You will get “The requested view does not exist or you have insufficient rights to access it.”
    You specified
    Widget type=”Chart” cnlNums=”601,602,603,604,605″ viewIDs=”2,2,2,2,2″
    in the dashboard settings.
    But you have to specify the existing view that really contains the channels 601…605
    May be viewIDs=”64,64,64,64,64″
    in reply to: Understanding Inputs Outputs and formulas #2734
    Of course.
    What a formula do you plan to use in mathematical manner?
    in reply to: Dashboard Chart #2730
    Hi Peter,
    I don’t think that the error relates to a new key. Anyway we need to solve it.
    View is a scheme or a table which is specified in the Interface table in Administrator.
    What is the URL of the page with the error?
    Copy here the errors from the logs of SCADA-Server and Webstation.
    Post here a link to a screenshot of the Interface table.
    Post here the dashboard configuration, please.
    in reply to: Chart Pro Y Axis scaling #2729
    This feature requires modification of the plugin source code. We could discuss the custom development by email.
    in reply to: Webpage Error Localhost and Remote #2728
    Please provide a screenshot of your Windows features dialog. I suppose, WCF was not installed.
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2727
    Cool!
    in reply to: Chart Pro Y Axis scaling #2720
    Y axis is scaled automatically depending on the range of values.
    Do you want fixed scaling by Y?
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2719
    It’s better to restore the default values:
    SCADA-Server uses port 10000.
    IIS web server (the web application) uses port 80.
    I suggest to help you by remote connection for a fee. It will save your time.
    in reply to: Telegram bug #2715
    This is something new.
    Please send me the content of C:\SCADA\ScadaComm\Config to reproduce the bug.
    Also describe the sequence to raise this error.
    • This reply was modified 8 years, 7 months ago by Mikhail.
    in reply to: sankey #2712
    You right to avoid writing email here.
    Please send your vision to email published here.
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2710
    Don’t use port 10000 for web application. It works on port 80 by default.
    What is shown by http://localhost/scada/Login.aspx ?
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2706
    Features seem OK.
    Try http://localhost/ Does it work?
    Please check, may be the default port 80 is used by another web server?
    in reply to: "," of numbers #2704
    If you set en-US or pt-BR, for example, formatting will be changed but the software loads the existing en-GB files.
    in reply to: Building a tank with a level bar #2702
    1. Create a set of images with different levels by your favorite graphical editor.
    2. Use Dynamic Picture component and define Conditions property to change image according to the current value.
    Note: a control library includes ready to use level control is under development currently.
