Please open C:\SCADA\ScadaWeb\config\WebSettings.xml in a text editor and check CommSettings section. These are the connection parameters for the web app. Can you provide them here?
MikhailModeratorWhat Windows language do you use?
Your issue is similar to this. But a user didn’t notify about the result. Please try the advice and write here whether it helps or not.
It’s easy to change culture, but it’s strange that Administrator stops. Could you provide more info about it?
MikhailModeratorTo send commands every 5 seconds by Automatic Control Module, you need to create a trigger fires on data change, and create an input channel that changes every 5 seconds.
MikhailModeratorAutomatic Control Module sends commands via output channels or directly to a device.
Do you really need to change input channels by commands?
Is it possible to provide a log of communication where we can see what packets were sent and received and timings?
Do you send commands by Rapid SCADA?
Please provide a screenshot with the settings of the module. I can’t find it in your files.What I intend to do is to insert 100 values based on a time schedule trigger for one input channel.How do I do that?
Could you clarify the task?
MikhailModeratorThe visible difference between en-GB and en-US is the date pattern. English is Day-Month-Year. US is Month-Day-Year. Does it change?
How you want to format values?
I answered here http://forum.rapidscada.org/?topic=installation-automatic-control-module
You did the right steps, but the version of the module you installed is newer that SCADA-Server. You should update the SCADA-Server app and then install the module again.
I installed the Automatic Control Module to insert a few hundred set of values automatically.Is that possible?
Yes, it’s normal.
Could you create a new topic in the appropriate subforum http://forum.rapidscada.org/?forum=installation-issues and copy your question?
This is a known error, I’ll help you.
Have you copied BaseDAT\*.dat files and restarted Server?
Do you login as administrator?
MikhailModeratorDownload this link. Then publish the web app similar to manual Webstation installation: http://doc.rapidscada.net/content/en/installation-and-run/manual-installation.html
Create an input channel of calculated real type and define its formula: Val(1) + Val(2), where 1 and 2 are the source channelsNovember 16, 2017 at 10:23 am in reply to: The " E_FAIL IOPCItemMgt.AddItems " Error occurred using the OPC connection #2812
Try this advice. Does the console app work?
