Hi there.
I have a problem installing the Automatic Control Module(trial), yes I havent not make any payment but I would like to try the trial version first.
You did the right steps, but the version of the module you installed is newer that SCADA-Server. You should update the SCADA-Server app and then install the module again.
I installed the Automatic Control Module to insert a few hundred set of values automatically.Is that possible?
