Viewing 15 posts - 4,561 through 4,575 (of 6,299 total)
  • in reply to: OPC write value issue-IBH opc server #4514
    In the above screenshot the method Group.Write is shown. It uses the Wrive method of a subscription. Can you navigate to Subscription.Write and check what is going there?
    in reply to: Events trigger and colors #4513
    Cool!
    May I ask you about the forum, do you receive notifications when I answer in the topic? Do they work well?
    in reply to: Reading bits #4511
    in Calculate Discrete – GetBit(Val(434),x)
    Yes. This is very important.
    in reply to: Reading bits #4510
    Fix channel 434:
    – No formula needed.
    – Type is Real, because the channel contains a bit mask, not just one bit.
    Fix other channels:
    – No Signal field needed.
    in reply to: Events trigger and colors #4509
    Thank you for the images.
    You need to open the Units table in Administrator. And create a new row with a new unit. Do at as written above. Then set the new unit for your input channel.
    in reply to: minute real and second counting issues #4505
    The description is detailed. Could you add some images explaining the issue?
    I already read old forum posts dating back to 2015 on this subject
    Please provide the link.
    I’m sure that it’s possible to solve this issue with help of formulas of the configuration database. However, I hope to find out the cause and fix if possible.
    in reply to: Events trigger and colors #4504
    Input channels, units that are related to the issue.
    in reply to: Device 11 – Server Room error #4503
    Thank you for updating the status.
    If you share more info about your research, it would be interesting.
    in reply to: OPC write value issue-IBH opc server #4499
    We can connect by Skype to find the solution together. If you OK with it, write me to info@…
    in reply to: Elastic Report Excel Issue #4498
    Could you provide a screenshot of the Excel and PDF reports where the difference is visible?
    in reply to: Events trigger and colors #4497
    See my previous message.
    in reply to: Device 11 – Server Room error #4496
    Did you watch this video and subsequent?
    in reply to: OPC write value issue-IBH opc server #4488
    I am sure that I can write with this method: IOPCSyncIO::Write
    To do this, the OPC driver have to be redesigned using another OPC client library.
    This is possible. However, I suppose that it would be much cheaper if the OPC server developer supports WriteVQT.
    What communication protocol do you use?
    Are there alternative OPC servers?
    Can you find OPC UA server? OPC UA .NET API is officially free.
    in reply to: Events trigger and colors #4485
    Please provide a screenshot of your configuration related to this issue.
    in reply to: Siemens Logo! Modbus #4484
    What recommendations are you referring to?
    First of all, copy here your actual communication log where we can see sending a command.
    If the PLC answer OK, you can:
    1. Compare binary packets with other software that works well.
    2. Contact the manufacturer for support.
