MikhailModeratorAgent is the application of Rapid SCADA. Agent is included in Rapid SCADA 5.7.
When you install Rapid SCADA 5.7, you will connect to VMs from Administrator installed on your workstation PC.
MikhailModeratorasync/await are efficient when you wait for response via some external channel, like network. SetCurData writes to the internal buffer of Communicator, so this approach doesn’t improve performance in this case.
I use a quite rapid device which refreshs at about 50Hz
It’s better to use PLC to collect data fast and then download data as a block.
MikhailModeratorHi Dawn,
I suggest Rapid SCADA 5.7.x
On the 1st VM install all the apps.
On the 2nd and 3rd install Communicator and Agent.As virtual device you can choose Martrikon OPC simulation server or use the included in Rapid SCADA KpSimulator.dll driver.
As I remember, only Chart Pro refreshes chart automatically.
You should try Chart Pro.
MikhailModeratorYou should try poll any addresses using Rapid SCADA. Some devices answer ILLEGAL ADDRESS, but others return correct response filling with zeros. If yours of the second type, you can find non zero registers.
MikhailModeratorAlso try WireShark
MikhailModeratorHi John,
Sure. Any time. We provide high quality and competitive price 🙂
Do you use the default Chart plugin or Chart Pro?
What is the version of the chart plugin?
In browser press F12 and check the Console tab for errors.
Do you know at least a communication protocol? Is it Modbus TCP or other one?
I researched for this, and I have’t found any free solution. We can develop such driver as a custom development by a contract.
MikhailModeratorYou have 2 options:
1. Install on RTU VM only Communicator which connects to the Server app of the main VM.
2. Install on RTU VM full Rapid SCADA and use Rapid Gate.about a key that would be needed to use the Rapid Gate. How would this be obtained?
Buy permanent key or use free trial
MikhailModeratorSeems like hardware problem. What USB-COM converter do you use?
June 19, 2019 at 1:57 pm in reply to: Spanish Translation of Rapid Scada Documentation Traducción Rapid Scada Español #5578
We have Spanish section in the documentation. It needs to be updated. To work with it, you should register GitHub, fork the repository, make your changes and create a pull request to include them into the project.
MikhailModeratorMay be other application uses the same port COM4.
