Viewing 15 posts - 3,466 through 3,480 (of 6,218 total)
  • Mikhail
    Why do you need 2 copies of Rapid SCADA on the same machine?
    May be it’s easier to use virtual machines. For example, you don’t install several PostgreSQL servers on a one machine even if it’s technically possible.
    If you want to create 2 different systems, you should create 2 projects in Administrator.
    If you want to create a 1 distributed system, you should create several profiles within a 1 project.
    All profiles use the same configuration database that is included in the project.
    Could I install and setup multiple ScadaServer seperate by port on same machine ?
    On Linux:
    You can copy Rapid SCADA to different folders like
    /opt/scada1/
    /opt/scada2/
    But during installation you need to change installation script to create daemons having different names.
    Files to update:
    apache/scada.conf
    daemons/scadaagent
    daemons/scadacomm
    daemons/scadaserver
    scadarestart.sh
    scadastart.sh
    scadastop.sh
    svc_install.sh
    svc_uninstall.sh
    ScadaAgent/*.sh
    ScadaComm/*.sh
    ScadaServer/*.sh
    Honestly, I don’t think it’s a good idea for beginning.
    in reply to: Errors with table view #7466
    Please press F12 in browser, open the Console tab and make a screenshot of the error details.
    What Windows version do you use?
    in reply to: How to send commands using KpMQTT #7464
    Now you should open the Output channel table in Administrator and create a new output channel. Specify a command number the same as you use for sending commands.
    In Scheme Editor, add a button for example, and set its output channel to the output channel number that you have created.
    in reply to: Grafana (backend) and Rapid SCADA #7459
    SCADA-Server uses TCP port 10000 for incoming connections. You should check that other software does not occupy it.
    in reply to: Grafana (backend) and Rapid SCADA #7458
    Could you also post here a part of the SCADA-Server log file? Let’s check how the server behaves in this period of time.
    in reply to: How to send commands using KpMQTT #7457
    Good. Please post screenshot of a command form (in Administrator), so I can tell you how to send similar commands from scheme.
    in reply to: Server problem #7452
    I’m very glad to read that the system is reliable now.
    Anyway in the next version Rapid SCADA engine is totally new, and I hope there will be no more such errors.
    in reply to: How to send commands using KpMQTT #7451
    I wander how to send command using KpMQTT via the Scheme Editor
    Before sending command from schemes, you should check that commands are successfully sent from Administrator. Have you already done that?
    in reply to: Redundancy in the upcoming Version 6 #7447
    In current version you can deploy an extra instance of Rapid SCADA like we do in our cloud solution. Also you should provide ability to poll controllers in parallel. Implementation depends on communication protocols.
    in reply to: Redundancy in the upcoming Version 6 #7445
    Yes, it is. It will support redundancy of data archive.
    in reply to: How to send commands using KpMQTT #7444
    1. A sending commands form in Administrator is general. Implementation depends on a particular driver. If you already able to successfully send commands using Administrator, I can describe how to do the same from schemes.
    2. Is this a string to be parsed? Why do you send different values in a one topic?
    Screenshots would help to understand your task.
    in reply to: Webpage Connection #7438
    @jacklondon
    is right. You should allow incoming connection to the HTTP port 80 on the Windows firewall.
    in reply to: Server problem #7435
    Thank you for the details.
    Could you try another approach for the same thing?
    Do the following:
    1. Make inactive the existing watchdog triggers.
    2. Create a new trigger that fires “On channel data change”
    3. Create a similar command for the new trigger and tick “Copy value or data” checkbox.
    4. Don’t use “Out channel” in the trigger command, but use “Device” and “Command” fields.
    Please let me know about the result.
