Viewing 15 posts - 3,391 through 3,405 (of 6,218 total)
  • in reply to: Questions regarding formular #7663
    It always tell me the you look like spam
    The is a protection plugin in the forum. The used rules like a back box. Without the plugin, there would be plenty of spam messages.
    in reply to: Storing the result of a formula with Database Import Driver #7660
    Is there a way to store data in a database automatically over time , without a prompt?
    You should use DB Export Module of SCADA-Server instead of DB Import driver.
    If I understood this correctly, the only way to save data is by sending a command, isn’t it?
    It’s true for DB Import Driver.
    • This reply was modified 5 years, 4 months ago by Mikhail.
    in reply to: ChartPro on IE11 Win10 #7659
    On my Win10 machine Edge was automatically replaced to the new Chrome-based version.
    Thank you for the script.
    in reply to: How to Use Dashboard plugins #7658
    You can change AspectRatio parameter that affects height. But it doe not resize vertically automatically.
    Try using WebPage view if you need only 1 chart on a page.
    in reply to: Acces the Modbus data from outside the LAN #7657
    And you need configure a router to forward the incoming requests to your Rapid SCADA server.
    in reply to: Acces the Modbus data from outside the LAN #7656
    If you need to access your office or home network from the internet, you need static IP address or dynamic DNS like https://www.noip.com/
    In the deployment profile you can adjust the webstation URL
    It just opens the specified URL. Doesn’t affect the real web site.
    in reply to: Integration with IAP #7655
    First, you should select Windows or Linux. It’s completely different.
    To discuss HTTPS, create a new topic.
    in reply to: Integration with IAP #7641
    1) Yes. It is implemented on the web app level.
    2) There is a plugin for automatic login. But it uses only 1 user name. To map between users, a new plugin should be developed.
    3) I recommend to configure the project using Windows and then upload to Linux.
    To setup https for Rapid SCADA on Linux, you should use a proxy.
    in reply to: Can’t get Computer Code for module registration #7640
    Thank you for the description of the final solution. I’m glad that you fixed it.
    in reply to: Dashboard Chart #7636
    The initial widget period is a constant. However, a user can change period in Chart Pro menu. After reopen, the period is set to initial value.
    in reply to: Storing the result of a formula with Database Import Driver #7635
    Please provide screenshots that illustrate your settings and system behavior.
    in reply to: Storing the result of a formula with Database Import Driver #7634
    Do you use Database Import Driver?
    in reply to: Can’t get Computer Code for module registration #7632
    The ModAutoControl.log file is empty.
    It means that the module doesn’t work.
    Please check ScadaServerSvc.log for additional info.
    in reply to: Integration with IAP #7627
    would be possible with linux version to be accessed by web
    Yes. Select Ubuntu.
    would be possible to use IAP to manage accesses to different resources for different users?
    I have no info about IAP, unfortunately.
    any way to simulate PLC and access to it from web?
    You can use Modbus simulator or OPC UA simulation server.
    in reply to: Administrator Find and Replace Bug #7626
    Thank you for the report. I tried to reproduce the bug on HelloWorld project. But it works well. Could you try to do the same on HelloWorld project?
    The app should remember the start search row. May be in some cases it fails.
