Viewing 15 posts - 2,746 through 2,760 (of 6,219 total)
  • in reply to: OPC UA Driver #9561
    Please try the update.
    Thank you for finding a bug.
    in reply to: OPC UA Driver #9558
    What is the driver version?
    Please provide screenshots of the settings and the error message, and communication line log.
    in reply to: couldn’t find basic and extra components in scheme editor #9557
    Try opening the PlgSchExtraComp.dll file properties and unblocking the dll.
    in reply to: Lost current data after reboot #9551
    The above answer is correct. In addition, I’d like to inform that in Rapid SCADA 6, current data can be flush on disk using the specified period to take care on a flash drive.
    in reply to: couldn’t find basic and extra components in scheme editor #9550
    If you installed the components, but the don’t appear, check the log file C:\SCADA\ScadaSchemeEditor\Log\ScadaSchemeEditor.log for the details.
    May be you need to unblock DLL files of the components.
    in reply to: Loggin server error #9544
    Open the services list in Windows and make sure that ScadaServerService is running.
    Also make a screenshot of the C:\SCADA\ScadaServer\Log\ folder
    in reply to: Can’t open server #9542
    The default configuration of Device 11 “ADAM-6015 Server room” works via Modbus TCP, not OPC server.
    in reply to: Time Zone oparating #9537
    It’s possible. Please provide a screenshot of the input channel properties that contains time.
    in reply to: Migrate plugin license key? #9533
    This topic is about license key. Please do not mess all questions in a one topic.
    Create new topic for different questions.
    The above question can be fixed in a short time.
    in reply to: Migrate plugin license key? #9527
    According to this page, “Modules are bound to a particular server. License keys can not be transferred to another server.”
    This is because of the technical reason. To allow transfer keys, it’s needed to check registration via Internet periodically, like Windows does, for example. SCADA software should not depend on the Internet connection.
    > the ways of the Lord are inscrutable
    We’re here on the ground in dust ))
    in reply to: Registration failed for “Extra Scheme Components” #9524
    You should register that components:
    1. Go to Main Menu > Registration > Extra Scheme Components.
    2. Register the plugin using the hyperlinks on the page.
    3. Download the changed Webstation settings to the project using the Administrator application.
    in reply to: Can not show Scheme View after active Pugin #9521
    Configuration database – System – Interface
    in reply to: Have no show Input channel in Table Editer #9520
    According to the log, you poll device using Modbus communication protocol, while asking about connecting to the OPC server.
    in reply to: Can not show Scheme View after active Pugin #9517
    To answer your question, screenshot of the Interface table is required.
    in reply to: Have no show Input channel in Table Editer #9516
    The above link is OK, but there is no screenshot that shows a communication line log.
