Forum Home › Forums › Communicating with Devices › OPC › Can’t open server
- This topic has 2 replies, 2 voices, and was last updated 5 years, 2 months ago by
September 22, 2021 at 9:13 pm #9539
ozimowski
ParticipantHello
I wants to display its variables from the opc server in the form of a table on the local host as in the instructional video (link here https://www.youtube.com/watch?v=SwBPyWFH5Ao). When it loads the configuration, it gets the information that the server is working properly, the communication is ok too, line state is running. But localhost rejects the connection. Here are my line logs.2021-09-22 21:34:57 Unable to communicate with Device 11 “ADAM-6015 Server room” because connection is not established
2021-09-22 21:34:57 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2021-09-22 21:34:58 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2021-09-22 21:34:58 Unable to communicate with Device 11 “ADAM-6015 Server room” because connection is not established
2021-09-22 21:34:59 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2021-09-22 21:34:59 Unable to communicate with Device 11 “ADAM-6015 Server room” because connection is not established
2021-09-22 21:35:00 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2021-09-22 21:35:00 Unable to communicate with Device 11 “ADAM-6015 Server room” because connection is not established
2021-09-22 21:35:01 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2021-09-22 21:35:01 Unable to communicate with Device 11 “ADAM-6015 Server room” because connection is not established
2021-09-22 21:35:01 Establish a TCP connection with 127.0.0.1:502
Error establishing TCP connection: Nie można nawiązać połączenia, ponieważ komputer docelowy aktywnie go odmawia 127.0.0.1:5022021-09-22 21:35:03 Unable to communicate with Device 11 “ADAM-6015 Server room” because connection is not established
2021-09-22 21:35:03 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2021-09-22 21:35:04 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2021-09-22 21:35:04 Unable to communicate with Device 11 “ADAM-6015 Server room” because connection is not established
2021-09-22 21:35:05 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2021-09-22 21:35:05 Unable to communicate with Device 11 “ADAM-6015 Server room” because connection is not established
2021-09-22 21:35:05 Stop communication line 1 “Modbus”
2021-09-22 21:35:18 Initialize communication line 1 “linia”
2021-09-22 21:35:19 Start communication line 1 “linia”2021-09-22 21:35:19 Communication session with the Device 1 “arduino”, type: KpOpc
2021-09-22 21:39:10 Initialize communication line 1 “linia”
2021-09-22 21:39:10 Start communication line 1 “linia”2021-09-22 21:39:10 Communication session with the Device 1 “arduino”, type: KpOpc
2021-09-22 21:45:51 Initialize communication line 1 “linia”
2021-09-22 21:45:52 Start communication line 1 “linia”2021-09-22 21:45:52 Communication session with the Device 1 “arduino”, type: KpOpc
2021-09-22 21:51:41 Initialize communication line 1 “linia”
2021-09-22 21:51:42 Start communication line 1 “linia”2021-09-22 21:51:42 Communication session with the Device 1 “arduino”, type: KpOpc
2021-09-22 21:53:54 Initialize communication line 1 “linia”
2021-09-22 21:53:55 Start communication line 1 “linia”2021-09-22 21:53:55 Communication session with the Device 1 “arduino”, type: KpOpc
2021-09-22 22:18:12 Initialize communication line 1 “linia”
2021-09-22 22:18:27 Start communication line 1 “linia”2021-09-22 22:18:27 Communication session with the Device 1 “arduino”, type: KpOpc
2021-09-22 22:40:34 Initialize communication line 1 “linia”
2021-09-22 22:40:34 Start communication line 1 “linia”2021-09-22 22:40:34 Communication session with the Device 1 “ard”, type: KpOpc
2021-09-22 22:46:23 Initialize communication line 1 “linia”
2021-09-22 22:46:24 Start communication line 1 “linia”2021-09-22 22:46:24 Communication session with the Device 1 “ard”, type: KpOpc
2021-09-22 22:50:27 Initialize communication line 1 “linia”
2021-09-22 22:50:28 Start communication line 1 “linia”2021-09-22 22:50:28 Communication session with the Device 1 “ard”, type: KpOpc
2021-09-22 22:54:22 Initialize communication line 1 “linia”
2021-09-22 22:54:22 Start communication line 1 “linia”2021-09-22 22:54:22 Communication session with the Device 1 “ard”, type: KpOpc
2021-09-22 22:55:28 Initialize communication line 1 “linia”
2021-09-22 22:55:28 Start communication line 1 “linia”2021-09-22 22:55:28 Communication session with the Device 1 “arduino”, type: KpOpc
2021-09-22 23:03:08 Initialize communication line 1 “linia”
2021-09-22 23:03:09 Start communication line 1 “linia”2021-09-22 23:03:09 Communication session with the Device 1 “arduino”, type: KpOpc
2021-09-22 23:11:26 Initialize communication line 1 “linia”
2021-09-22 23:11:27 Start communication line 1 “linia”2021-09-22 23:11:27 Communication session with the Device 1 “ard”, type: KpOpc
September 22, 2021 at 9:40 pm #9540ozimowski
ParticipantLocal host it also does not work on the base program hello world
September 23, 2021 at 11:36 am #9542
The default configuration of Device 11 “ADAM-6015 Server room” works via Modbus TCP, not OPC server.
