December 15, 2025 at 10:56 am in reply to: Need download link for Rapid SCADA 5.1.x (Windows) #17411
I’ve added the updated links here.I suppose, you should check the errors in communication line log. Maybe configure communication channel manually.
MikhailModeratorProjConv5to6_dotnet8
HistConv5to6_dotnet8
EventConv5to6_dotnet8-
This reply was modified 5 months, 3 weeks ago by
December 12, 2025 at 12:08 pm in reply to: Rapid SCADA Migration to VMWare – No Chart Pro, Dashboard or Views #17407
MikhailModeratorTo discuss “The requested view is not specified”, an issue description should contain:
– only appropriate question
– corresponding screenshots and log files.December 10, 2025 at 1:26 pm in reply to: MQTT Publisher publishes wrong values (e.g., 2.6E-322) instead of OPC DA values #17405
MikhailModerator> connection forced to close by remote host
That’s bad if occurs often, but not related to the data sent by MQTT.December 10, 2025 at 1:24 pm in reply to: MQTT Publisher publishes wrong values (e.g., 2.6E-322) instead of OPC DA values #17404
Please copy the corresponding log parts to this topic.
I have no access to we.tl for some reason. Please use Google Drive or another file hosting.
MikhailModeratorThe old versions are not available for download. Please use the up to date version.
MikhailModerator> The application is not ready. Try again later.
Check the details in ScadaWeb.log
Likely, it’s needed to wait the web app to start.> The requested view is not specified
Please create a new topic to resolve this issue.
Let me know what links are broken to repair them.
If your project < 1000 channels, I suggest to create a new project from scratch. It's possible to simply copy Modbus, OPC settings, and views.
Please check the differences here.
The format of projects and data in the specified versions were not changed. So you can continue using the installed version if you don’t need the features listed in the version history.
MikhailModeratorUsing virtual machines with Rapid SCADA is a good choice.
MikhailModeratorš
Please check this answer.
Please send an email request to get the deprecated release. When you download the project, I strongly recommend to upgrade to the 6th version.December 8, 2025 at 11:03 am in reply to: Errors when migrating existing project to a VMware instance #17387
The Administrator application is run under user account. Possible, it does not have access the project location.
> Channel data has changed fires every time Iām uploading configuration, and another disadvantage
What event is generated on restart? -
