MikhailModeratorYou can find commands in SCADA\ScadaWeb\*.bat
MikhailModeratorYou right. On Windows, IIS manages the web application. While on Linux there is a service for ScadaWeb.
The Administrator app sends a command to IIS to restart. Sometimes it takes a long. Even if you run the same command from a command line, the result would be the same. For now, I have no idea how to fix that programmatically. As for me, I open IIS management console and restart the web app using it. There is no delay in this way.
This issue presents only on Windows.
MikhailModeratorWhy isn’t “ScadaInstanceConfig.xml” file shown as a “child” object in the “Administrator” application’s GUI
Because ScadaInstanceConfig.xml is not a part of a user’s project. It’s possible to develop an extension that provides UI for editing ScadaInstanceConfig.xml.
MikhailModeratorDo you mean creating nested folders in the View Explorer tree?
MikhailModeratorThank you 🙂
MikhailModeratorIn the Views table you should set the view type for the record with ID=7.
Tables and schemes are detected by their file extension, while dashboards use common extension XML.
MikhailModeratorI also cannot open the screenshots. Please check.
Links in the 2nd message work.-
This reply was modified 2 years, 8 months ago by
According to the settings, events should be generated when channel status has changed. Does the channel status change when you change channel value from -1 to 1, for example?
Next time, please make screenshots in English.
MikhailModeratorAutomatic Control Module works in this way. It can send command when condition is met. According to the command, channel value can be simply increased.
MikhailModeratorYou need an additional variable to store a flag that the condition change has already processed. After adding 1, set the flag ON. When the condition becomes false, set the flag to OFF. The formula is not very simple, because it executes in a loop as written above.
Alternatively, you could increase a channel inside the formula of the condition if it’s applicable.
September 14, 2023 at 10:51 am in reply to: How to use a c# script to process input XML/MQTT message #13372
MikhailModeratorSeptember 14, 2023 at 10:50 am in reply to: How to use a c# script to process input XML/MQTT message #13371
MikhailModeratorAlso you need to specify subitems.
September 14, 2023 at 10:49 am in reply to: How to use a c# script to process input XML/MQTT message #13370
If you need to use JS to extract values from JSON, set JavaScript enabled = Yes (in device properties). Create a js file, put it in the Communicator configuration. Specify the file name in the JavaScript file name property.
MikhailModeratorPlease create a new topic to discuss configuration of the Dashboard plugin. Provide links to screenshots of your settings.
