MikhailModeratorThank you for the detailed description.
I’m thinking about development of a separate module for event generating. This approach can be more configurable and flexible than trying to add all possible features in the Server app.
MikhailModeratorThere is a feature named “reverse connection” supported by Agent. If you don’t know an IP of the Linux machine, it’s Agent can establish connection with your workstation. If it’s useful, I can provide more info.
what are all the files need to be copied?
The files that located in
SCADA\BaseDAT
SCADA\ScadaComm\Config
ScadaServer\Config
SCADA\ScadaWeb\config
SCADA\ViewsNovember 3, 2023 at 10:47 am in reply to: How to use a c# script to process input XML/MQTT message #13586
MikhailModeratorI suggest, first, to configure MQTT driver for reading simple numeric values. When it’s done, try using JSON. If you provide screenshots of the configuration and result, I can help more detailed.
November 3, 2023 at 10:45 am in reply to: How to use a c# script to process input XML/MQTT message #13585
Please check this post.
Values extracted from JSON are tags of Communicator. They bound to channels and displayed in a common way.November 3, 2023 at 10:43 am in reply to: Unable to communicate with Device 1 because connection is not established #13584
MikhailModeratorThere are Modbus scanner apps. They can read available integer registers, but do not provide info what a register means. And probably they are not efficient with floating point numbers.
November 2, 2023 at 8:51 am in reply to: Unable to communicate with Device 1 because connection is not established #13577
Modbus register addresses and data types should be specified in the device documentation, or declared by a PLC developer. The Modbus protocol does not support providing the list of registers from a device.November 1, 2023 at 9:50 am in reply to: Unable to communicate with Device 1 because connection is not established #13575
Access to the files is denied. Could you share the files?
Archive options can be found in Server – Archives.
May be ask a more specific question.October 31, 2023 at 12:39 pm in reply to: Unable to communicate with Device 1 because connection is not established #13569
MikhailModeratorDevice template is not the cause of that error. You should check the device settings.
October 30, 2023 at 8:52 am in reply to: Unable to communicate with Device 1 because connection is not established #13566
May be the controller’s IP address is not specified in the device settings. Please follow this article.October 26, 2023 at 1:09 pm in reply to: Using Formulas to count values and send them to MODBUS #13564
MikhailModeratorThe question about measuring time should be in a separate topic. Thank you.
MikhailModeratorInside the server logic there is a matrix created based on object inheritance and role inheritance. I hope, in the future we will somehow display that matrix for understanding.
MikhailModeratorYes, the idea of inheritance is joining roles.
MikhailModeratorIf a user has access rights to a parent object, he have access to child objects. No need to explicitly specify rights on the child objects. It saves a time needed for configuration.
Please write a question to a proper topic or create a new one. -
