MikhailModeratorHello Sergey,
The address 2 is got from the configuration database.
You can change it using SCADA-Administrator. Do not forget to pass changes to SCADA-Server and restart SCADA-Communicator.
For test purposes you could switch off the option ‘Use SCADA-Server’ in SCADA-Communicator. In this case the address specified in SCADA-Communicator is used.
MikhailModeratorYou definitely right. Not all the applications have been ported to Raspi yet. We are not going to do porting of GUI applications such as SCADA-Administrator. The idea is to make possible to perform configuration using web in the future.
At the current time you should configure your system using Windows, then copy the settings to Raspberry. Is it possible for you? You need to copy files from the following directories:
SCADA\BaseDAT
SCADA\ScadaComm\Config
SCADA\InterfaceIt would be wondering if you share you experience and issues of using Rapid SCADA on Raspberry Pi.
Thanks!
The defaults are
admin/12345
guest/12345It is recommended to change the default user names and passwords using SCADA-Administrator.
MikhailModeratorHello Darren,
Try checking the installation of WCF 4 or 4.5. It is a part of .NET Framework required for the schemes. Depending on the version of Windows it can be among Windows features.
Is there ScadaScheme.log in C:\SCADA\ScadaWeb\log ? If it exists, what does it contain?In the future versions we are going to use pure HTML5+JavaScript and such problems will disappear.
MikhailModeratorProbably your vague memorials is about other protocol than Modbus )
Modbus has special error codes for such cases or device does not respond anything.
Good luck in experiments! Your questions help others to solve their issues.
MikhailModeratorThe device responses the same bytes as were requested.
According to MODBUS APPLICATION PROTOCOL SPECIFICATION and MODBUS MESSAGING ON TCP/IP IMPLEMENTATION GUIDE the content of the response is definitely wrong.You can get proper communication log for comparison by using Modbus emulator mod_RSsim
Could you write a piece of log here?
MikhailModeratorTry the following:
1. Create a simple console application that play a sound. You can use Microsoft Visual Studio 2013 Community Edition.
2. In the formula call
System.Diagnostics.Process.Start(“C:\\MyPath\\PlaySound.exe”);
3. Be careful using such formulas. Do not use them for calculated channels.Please, write here about the result.
Formulas are calculated on a server machine by SCADA-Server service.
Most likely Windows doesn’t allow services to access a sound card.
What device should play a sound in your case?
MikhailModeratorSCADA-Web has been ported. Welcome to use Rapid SCADA on Raspberry Pi.
MikhailModeratorSorry, I don’t get into the way of using GUI on Linux.
Just install Midnight Commander
sudo apt-get install mc
and run the necessary scripts.
Also it is a good idea to use Putty to remote connection to your device.I hope that SCADA-Web for RPi will be ready within a few days.
MikhailModeratorCould you tell more about the system that you are going to implement? The understanding of the aim helps me to suggest the best solution.
MikhailModeratorPorting of SCADA-Web is under construction. You can wait for it or fork the project on GitHub and make the necessary changes.
MikhailModeratorThe web application SCADA-Web can be deployed on any free ASP.NET hosting in the Internet or in your LAN. SCADA-Web connects to Raspi and retrieves the data.
This reply was modified 10 years, 12 months ago by
MikhailModeratorThe one of known issues – Raspi doesn’t contain real time clock. That’s why after reboot a system, SCADA may write data with incorrect timestamp. This issue can be solved by writing special script that starts SCADA after a clock sync.
