username and password after installation in raspberrypi
Forum Home Forums Installation Issues SCADA-Web Installation username and password after installation in raspberrypi
  • #253
    ciluuk
    Dear Administrator,
    this is 1st time i try rapidscada, running on Raspi with raspibian.
    all installation is smooth until finished command, what is username and password??
    sudo mono-xsp4-admin add –path=/etc/scada/ScadaWeb –app=scada
    rapid scada first demo
    #254
    The defaults are
    admin/12345
    guest/12345
    It is recommended to change the default user names and passwords using SCADA-Administrator.
    #255
    ciluuk
    Hi Mikhail,
    Thank you for prompt reply,
    apologize for this question but i don’t find SCADA-Administrator here.
    i try to read all manuals, but all the manual refer to windows environment.
    in my Raspi Desktop, only mono manuals available.
    thank you.
    #256
    You definitely right. Not all the applications have been ported to Raspi yet. We are not going to do porting of GUI applications such as SCADA-Administrator. The idea is to make possible to perform configuration using web in the future.
    At the current time you should configure your system using Windows, then copy the settings to Raspberry. Is it possible for you? You need to copy files from the following directories:
    SCADA\BaseDAT
    SCADA\ScadaComm\Config
    SCADA\Interface
    It would be wondering if you share you experience and issues of using Rapid SCADA on Raspberry Pi.
    Thanks!
