MikhailModeratorThis function has not been developed. I mean that you could purchase the development.
Yes, you right. When you use Automatic Control Module, an output channel formula does not work, because the output channel is not specified in the trigger commands. To implement this function the development is required. If you really need this, you could purchase the upgrade.
Yes, it is possible with help of Automatic Control Module. You should create a command trigger and a set of commands bound to it.
MikhailModeratorHi Dejan,
Thanks for the response. The bug was fixed. You can download the installation package again and reinstall SCADA-Server.
MikhailModeratorYou should download the components of the version 4.5. They have been published recently.
September 22, 2015 at 7:12 am in reply to: How to get the data which automatically sent by the devices? #544
MikhailModeratorSpecial device driver is needed. Driver development is described here http://rapidscada.org/device-drivers-development/
You could develop it by yourself or purchase it.
MikhailModerator400001 means that you should select Holding Registers (4x) data table and the 1st start element address.
September 21, 2015 at 3:38 pm in reply to: How to get the data which automatically sent by the devices? #539
MikhailModerator1. Could you provide an example, please?
2. Probably you should implement or purchase development of the device driver if your device uses its own communication protocol.
What version of Rapid SCADA do you use?
MikhailModeratorNo, it’s free. There is an extended commercial version.
MikhailModeratorStrange. May be it is cached. I’ve sent by e-mail.
Or you can download the distributive from rapidscada.org
MikhailModeratorIt is too old.
Should be 17.09.15 and 27648 bytes. Please update.
MikhailModeratorCould you post here the size and modify date-time of C:\SCADA\ScadaWeb\bin\ScadaDiag.dll ?
MikhailModeratorShow chart issue:
Try pressing Ctrl+F5 to fully refresh the web page. The location of ScadaDiag.aspx was changed to diag/Diag.aspx
MikhailModeratorMy advice was inaccurate.
You should create an output channel with standard command type.
In the source of your formula create a byte array of 8 elements:byte[] arr = new byte[8];
Fill it by the required values. Then convert back to double using BitConverter class:
return BitConverter.ToDouble(arr) -
