Forum Home › Forums › Installation Issues › Failed to Invoke: ShowDiag error
- This topic has 14 replies, 2 voices, and was last updated 11 years ago by
September 18, 2015 at 10:13 am #514
epoch79
ParticipantHi Mikhail,
I upgrade scadaweb to 4.5 but having some problems.
When I click the diynamictext to show data i get “Failed to Invoke: ShowDiag” error.
I realised that the Diag.aspx is absent.
Also there is same issue for the SendCmd to.
am i missed something or this files is not going to be in develop branch ?thanks.
September 18, 2015 at 1:23 pm #520epoch79
ParticipantUygulama Hatası: Belirtilen atama geçerli değil.
konum: Scada.Web.Diag.WFrmDiag.Page_Load(Object sender, EventArgs e)
konum: System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Page: http://localhost/Scada/diag/Diag.aspx?viewSet=0&view=4&year=2015&month=9&day=18&cnlNum=101ScadaWeb Log
September 18, 2015 at 1:33 pm #521
MikhailModeratorWhen you updated SCADA-Web? The 2nd bug was fixed in this week.
Try downloading again and overwrite ScadaDiag.dllSeptember 18, 2015 at 1:36 pm #522epoch79
ParticipantI updated today.
September 18, 2015 at 1:48 pm #523epoch79
ParticipantI download from this adres but stil same error
http://rapidscada.org/download/scada_4.5_update.zipSeptember 18, 2015 at 6:43 pm #524
MikhailModeratorThis is outdated link. I will check the errors you described.
September 18, 2015 at 6:54 pm #526
MikhailModeratorShow chart issue:
Try pressing Ctrl+F5 to fully refresh the web page. The location of ScadaDiag.aspx was changed to diag/Diag.aspxSeptember 18, 2015 at 7:08 pm #527
MikhailModeratorCould you post here the size and modify date-time of C:\SCADA\ScadaWeb\bin\ScadaDiag.dll ?
September 18, 2015 at 9:18 pm #528epoch79
Participant11.09.2015
26 kbSeptember 18, 2015 at 9:42 pm #529
MikhailModeratorIt is too old.
Should be 17.09.15 and 27648 bytes. Please update.September 18, 2015 at 9:59 pm #530epoch79
Participantwhere can i get that.
you released 4.5.1 a little while ago.
I looked at the ScadaDiag.dll file its same 11.09.2015 23:15 26.112 kbSeptember 18, 2015 at 10:02 pm #531epoch79
Participantsorry its not in 4.5.1 release. i look at the same zip file.
Ok. Where can i get this dll again ?September 18, 2015 at 10:06 pm #532
MikhailModeratorStrange. May be it is cached. I’ve sent by e-mail.
Or you can download the distributive from rapidscada.orgSeptember 18, 2015 at 10:16 pm #533epoch79
Participantthank yo for the mail.
its solved the problems.
one more question is there any expire date for this scadadiag.ddl ?September 18, 2015 at 10:19 pm #534
MikhailModeratorNo, it’s free. There is an extended commercial version.
