MikhailModeratorYou can set bounds for an input channel using SCADA-Administrator. When the channel value is above or below defined limits, event is generated.
If you need events when device turned ON or OFF, you should create additional channels of the type Calculated discrete and tick Write events and Events on change checkboxes for these channels.
MikhailModeratorSCADA-Web connects to SCADA-Server using TCP port 10000. Check the connection settings with SCADA-Web Configurator utility.
Port 80 is used by IIS. I should not use it for other purposes.
MikhailModeratorBrowse OPC Server via UI of SCADA-Communicator doesn’t depends on connection with SCADA-Server. What error message appears?
You have to allow incoming TCP connection through 10000 port on a firewall on a PC where SCADA-Server installed.
MikhailModeratorAny information about your project is welcome 🙂
MikhailModeratorHi Ali,
What OS do you use?
Good news 🙂
Thank you for your help in finding the cause.
I’ll include the fix in the distributive within a few days.
MikhailModeratorYou have found a major bug. Thanks!
I’ve sent you a fix. Please try it and post a result here.Do not forget to return Device request retries count on error back to 3.
1. The additional component ChartList
2. Component for ChartingThese components are commercial. I will send you an offer by e-mail.
MikhailModeratorThis is the frequent question. In the current version 4.5 you can display a gauges and meters using a set of images. Each image for the each value. Otherwise use text labels. In the spring of 2016 we are going to create a new SCADA-Web with required graphical components.
MikhailModeratorI agree that the manual is not rich of examples. In case of restricted resources the best way is to simplify the UI to allow a user easily understand how to configure a system.
This forum is a knowledge base. Be free to ask for examples (in a new topic).
MikhailModeratorGoogle Translate translates German completely unclear )
MikhailModeratorThanks for the improvements of the instruction )
I use WinSCP for copying files from my Windows workstation. And Putty with MidnightCommander (mc) to run scripts.
Have you solved the issue caused by decimal separator?
MikhailModeratorYou can import C:\SCADA\BaseDAT\formula.dat from the distributive v4.5 using SCADA-Administaror. It contains GetBit function.
MikhailModeratorHi!
GetBit appears since Rapid SCADA v.4.5
I think you have tried to use this formula in v.4.4
MikhailModeratorHi!
If you use the same monitor, check scaling in your browser.
