Viewing 15 posts - 46 through 60 (of 6,265 total)
  • in reply to: Event beep #17833
    You could find and replace the file. Is is in the ScadaWeb folder.
    Also try Notifocation Plugin.
    in reply to: Webstation hourly values issue #17814
    1. I suggest to set the channel’s archive mask to an empty value. In that case, channel values will be written in the default archives.
    2. Upload the HelloWorld project for execution and make sure that it writes hourly values.
    3. Check ScadaServer.log and ScadaServer.txt for errors and additional info.
    • This reply was modified 1 month, 2 weeks ago by Mikhail.
    in reply to: Webstation hourly values issue #17811
    Please clarify your question by providing screenshots.
    in reply to: How to integrate MQTT into a script #17809
    The Server scripting engine has no references to the MQTT classes.
    What is the general idea of ​​how the script should work?
    I suggest this manual about Server scripts https://rapidscada.net/docs/en/latest/configuration/scripts
    in reply to: Scheme title #17806
    This is a known bug. It will be fixed in the next release.
    in reply to: Setting up postgreSQL #17805
    I’m glad everything worked 🙂
    in reply to: Setting up postgreSQL #17802
    If you want all channels to be written in the custom archive, set the Is Default field for the archive.
    in reply to: Setting up postgreSQL #17801
    Let’s make the custom archive work!
    Note that you should add a custom archive with the same Code to the Server settings, and to the Archives table in the configuration database.
    If this has already been done, please send screenshots of the relevant settings.
    Please provide more details and screenshots.
    in reply to: Mobile resolution or view #17797
    A variation on the same idea:
    1. Deploy a separate instance of the web application for mobile users.
    2. Add views for mobile in a different folder.
    3. Set a corresponding start view for mobile users in the web app settings.
    in reply to: SCADA not running #17793
    It looks like something wrong with the web application. If you start the Scada website in the IIS management console, what happens next?
    in reply to: Entering future data #17790
    As a first step, try writing historical data to the future using ScadaTestClient.
    If data successfully saved and displayed, then we can think how to read them by a driver.
    • This reply was modified 1 month, 4 weeks ago by Mikhail.
    in reply to: Delayed control sequence #17784
    Try changing channel values by ScadaTestClient in order to test triggers separately.
    in reply to: Delayed control sequence #17781
    Note that a trigger fires when a channel value changes. I mean that the trigger condition should be false, and after that the condition should be true to cause the trigger to fire. Did it happen?
    If the channel is undefined, the trigger condition neither true or false as I remember.
    • This reply was modified 2 months ago by Mikhail.
    in reply to: Delayed control sequence #17780
    If the channel is specified, the object is redundant here.
    According the above part of the log, the fallback trigger does not fire.
