Viewing 15 posts - 5,191 through 5,205 (of 6,265 total)
  • in reply to: Telegram bug #2747
    Thanks a lot!
    I’ll try the next week and let you know.
    in reply to: Understanding Inputs Outputs and formulas #2746
    πŸ™‚
    in reply to: Webpage Error Localhost and Remote #2745
    The screenshot is not accessible.
    in reply to: Dashboard Chart #2740
    OK πŸ™‚
    in reply to: Telegram bug #2739
    Do you still want me to send you any data?
    I also tried to reproduce the bug. But I can’t. I’m sure the bug exists, but we need to know the magic sequence how to raise it. If you realize this sequence, tell me, please. You don’t need to send me the config now.
    in reply to: Chart Pro Y Axis scaling #2736
    I sent an email.
    in reply to: Dashboard Chart #2735
    Thank you for the link. It’s better than a screenshot.
    Try http://fischerp.selfhost.eu:8888/Scada/View.aspx?viewID=2
    You will get “The requested view does not exist or you have insufficient rights to access it.”
    You specified
    Widget type=”Chart” cnlNums=”601,602,603,604,605β€³ viewIDs=”2,2,2,2,2β€³
    in the dashboard settings.
    But you have to specify the existing view that really contains the channels 601…605
    May be viewIDs=”64,64,64,64,64β€³
    in reply to: Understanding Inputs Outputs and formulas #2734
    Of course.
    What a formula do you plan to use in mathematical manner?
    in reply to: Dashboard Chart #2730
    Hi Peter,
    I don’t think that the error relates to a new key. Anyway we need to solve it.
    View is a scheme or a table which is specified in the Interface table in Administrator.
    What is the URL of the page with the error?
    Copy here the errors from the logs of SCADA-Server and Webstation.
    Post here a link to a screenshot of the Interface table.
    Post here the dashboard configuration, please.
    in reply to: Chart Pro Y Axis scaling #2729
    This feature requires modification of the plugin source code. We could discuss the custom development by email.
    in reply to: Webpage Error Localhost and Remote #2728
    Please provide a screenshot of your Windows features dialog. I suppose, WCF was not installed.
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2727
    Cool!
    in reply to: Chart Pro Y Axis scaling #2720
    Y axis is scaled automatically depending on the range of values.
    Do you want fixed scaling by Y?
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2719
    It’s better to restore the default values:
    SCADA-Server uses port 10000.
    IIS web server (the web application) uses port 80.
    I suggest to help you by remote connection for a fee. It will save your time.
    in reply to: Telegram bug #2715
    This is something new.
    Please send me the content of C:\SCADA\ScadaComm\Config to reproduce the bug.
    Also describe the sequence to raise this error.
    • This reply was modified 8 years, 6 months ago by Mikhail.
