Viewing 15 posts - 5,146 through 5,160 (of 6,265 total)
  • in reply to: How to use Automatic Control Module #2853
    I can help you to create a formula for such channel if you need.
    in reply to: E_Network Error #2852
    What is the OPC server you use?
    in reply to: E_Network Error #2851
    Please try Matrikon OPC Simulation server. Does it work?
    Also try to browse the OPC server by this utility. What is the result?
    in reply to: Server is unavailable #2849
    The format of the WebSettings.xml file was changed. You should take the new one from the distributive.
    You don’t need CommSettings.xml for the web app no more.
    in reply to: Server is unavailable #2843
    Also check CPU load of ScadaServerSvc.exe.
    in reply to: Server is unavailable #2842
    Please open C:\SCADA\ScadaWeb\config\WebSettings.xml in a text editor and check CommSettings section. These are the connection parameters for the web app. Can you provide them here?
    in reply to: Administrator Installation Issue #2840
    What Windows language do you use?
    in reply to: Administrator Installation Issue #2839
    Your issue is similar to this. But a user didn’t notify about the result. Please try the advice and write here whether it helps or not.
    It’s easy to change culture, but it’s strange that Administrator stops. Could you provide more info about it?
    in reply to: How to use Automatic Control Module #2837
    To send commands every 5 seconds by Automatic Control Module, you need to create a trigger fires on data change, and create an input channel that changes every 5 seconds.
    in reply to: How to use Automatic Control Module #2836
    Automatic Control Module sends commands via output channels or directly to a device.
    Do you really need to change input channels by commands?
    in reply to: Slow Modbus Test #2835
    Is it possible to provide a log of communication where we can see what packets were sent and received and timings?
    Do you send commands by Rapid SCADA?
    in reply to: How to use Automatic Control Module #2832
    Please provide a screenshot with the settings of the module. I can’t find it in your files.
    What I intend to do is to insert 100 values based on a time schedule trigger for one input channel.How do I do that?
    Could you clarify the task?
    in reply to: "," of numbers #2829
    The visible difference between en-GB and en-US is the date pattern. English is Day-Month-Year. US is Month-Day-Year. Does it change?
    How you want to format values?
    in reply to: Automatic Control Module error #2828
    in reply to: Installation Automatic Control Module #2825
    You did the right steps, but the version of the module you installed is newer that SCADA-Server. You should update the SCADA-Server app and then install the module again.
    I installed the Automatic Control Module to insert a few hundred set of values automatically.Is that possible?
    Yes, it’s normal.
