Viewing 15 posts - 4,726 through 4,740 (of 6,266 total)
  • in reply to: Siemens Logo! Modbus #3972
    You may contact the Logo support, provide them communication log and ask for explanation about the device behaviour.
    in reply to: Elastic Report Flexibility #3970
    Could you send me an email to this address? I will estimate a cost of the update and answer by email.
    in reply to: Events not being fired #3969
    Try switching the event filter to “All Events”. May be they are not visible.
    Also look for the events in the GUI of SCADA-Server.
    We need to understand if there no events at all or they are hidden.
    Please write here about the result.
    in reply to: Siemens Logo! Modbus #3966
    According to the communication line log, the device understands your command. Nothing happens because of a device logic. You should check that you specify the correct address and value of the commands.
    Does the manufacturer provide an utility application that can send the required commands to compare data packages?
    in reply to: Responsive Web Design #3959
    I’m sure how do you expect them to work.
    in reply to: log storage location #3958
    Probably. You should test.
    in reply to: ModDBExport #3955
    In my opinion, this is not optimal. I think, the best way is export the configuration database to the external DB and, because of this, have a relation between channels and devices (and other information).
    To export the configuration database we should develop a module that would be integrated with Administrator.
    in reply to: log storage location #3953
    You can set the path of data archives in the SCADA-Server settings:
    SCADA/ScadaServer/Config/ScadaServerSvcConfig.xml
    in reply to: Responsive Web Design #3952
    Could you provide an example of a basemap?
    in reply to: log storage location #3944
    What logs do you need to save to the external disk?
    in reply to: HTTPS on Linux #3943
    I’m going to continue work on this issue.
    Thank you for help with testing.
    in reply to: Responsive Web Design #3942
    in reply to: Responsive Web Design #3941
    Rapid SCADA works on different devices and different screens. If some layout is not optimal, let’s discuss in particular.
    in reply to: HTTPS on Linux #3935
    Waiting for the news from you.
    On the next week I will try on my Linux computer.
    in reply to: HTTPS on Linux #3932
    On the next week, I can compare with my Linux machine.
