Viewing 15 posts - 4,516 through 4,530 (of 6,266 total)
  • in reply to: Create gauge, bar,… #4550
    that’s success, but i didn’t see that element which i design in ScadaSchemeEditor.exe. I wonder maybe lack of step in my implement. Can you assist me?
    I can connect to you remotely and fix the issue together with you. This is a commercial service.
    Anyway, you should see log file of Scheme Editor.
    in reply to: Create gauge, bar,… #4549
    yes, but i didn’t fix this issue.
    You can try downloading the project by GIT tools like GitHub desktop.
    in reply to: OPC write value issue-IBH opc server #4543
    “21 protected object m_group;”
    So if you create a new class that is derived from Subscription, you can add your own write method of Subscription and use needed m_group.Write.
    How do we find another overloaded m_group.Write?
    Open the Group class and find all Write method in it. Or just scroll down the tree shown in the last screenshot.
    in reply to: Create gauge, bar,… #4542
    It’s seems these files are blocked by Windows because they were downloaded from the internet. Did you already goole this issue?
    in reply to: OPC write value issue-IBH opc server #4535
    I suppose, m_group field is not public. Am I right? Is it protected or private?
    We should use other overloaded m_group.Write
    in reply to: OPC write value issue-IBH opc server #4533
    Do you know a software that open and debug dll files? with visual studio does not show the code.
    VS can show the code if a DLL is complied in debug configuration.
    Good screenshots. Thank you.
    The 3rd screenshots shows that WriteVQT is used.
    What about m_group variable? May be it contains other method for writing in addition to WriteVQT?
    I see that m_group uses m_subsription.Write and m_subsription executes m_group.WriteVQT
    • This reply was modified 7 years, 6 months ago by Mikhail.
    in reply to: OPC write value issue-IBH opc server #4530
    When debug is in progress please you do the following:
    1. Stop on a breakpoint on line 393 shown here
    2. Step into the Write method and watch what particular Write method is executed in line 393?
    in reply to: OPC write value issue-IBH opc server #4525
    We can see that m_subscription has ISubscription type that is an interface.
    We need to find out which class implements ISubscription and what is inside Write method.
    Do you able to attach to this library by a debugger in runtime?
    in reply to: M-Bus Protocol driver #4524
    It would be good, if you describe pricing options.
    in reply to: Reading bits #4523
    434 is the source channel that have to be full as received from a device.
    in reply to: Reading bits #4522
    You need to apply #4508
    I did not understand, why I dont need formula for channel 434
    Because if you get only 1 bit in the channel 434, you can’t reference 434 to calculate bits for other channels.
    in reply to: Events trigger and colors #4520
    Thanks!
    in reply to: OPC write value issue-IBH opc server #4514
    In the above screenshot the method Group.Write is shown. It uses the Wrive method of a subscription. Can you navigate to Subscription.Write and check what is going there?
    in reply to: Events trigger and colors #4513
    Cool!
    May I ask you about the forum, do you receive notifications when I answer in the topic? Do they work well?
    in reply to: Reading bits #4511
    in Calculate Discrete – GetBit(Val(434),x)
    Yes. This is very important.
