Viewing 15 posts - 4,381 through 4,395 (of 6,278 total)
  • in reply to: Web Application on Windows Server 2012 R2 #4940
    1. Before running Rapid SCADA setup, you should switch on the features of Windows Server 2012 R2. If you provide link to their screenshot, I’ll write what features to select.
    2. Microsoft SQL Server Compact 3.5 is used for configuration only, not for data archive. You can’t change it to SQL 2018. In the future we will get rid of SQL Server Compact.
    in reply to: Averaging formula #4937
    I implemented several averaging formulas in different projects. I can help you with averaging based on your requirements. But this is out of free support.
    in reply to: Time Out #4936
    You need to find a cause of logout. What operation system do you use? What is written in ScadaWeb.log when logout?
    in reply to: Averaging formula #4935
    How to do to average same variable along a certain time (n previous
    readings)?
    Create new formulas in the Formulas table depending on your needs. There are many different ways to calculate averages.
    What does “averaging” column in Input Channels work if marked?
    Summarizes all values received from controller and then divide by their count. This is performed separately when write minute and hourly data in the archive.
    in reply to: Averaging formula #4930
    Something like
    (Val(1) + Val(2) + Val(3)) / 3
    where 1, 2 and 3 are input channel numbers.
    You need to add an extra input channel of calculated real type that uses the above formula.
    in reply to: Installation of Webstation plugins #4929
    Rapid Scada 5.6.0 that includes Webstation to 5.0.7.0 ))
    in reply to: 5.6.0 Web is not normal #4924
    We fixed a bug that may relates to your issue. Download the latest Rapid SCADA again, reinstall Webstation and press Ctrl+F5 in browser.
    in reply to: Error in packaging the project #4923
    In this forumn, 1 topic is for 1 kind of error. Please create new topics for new errors.
    in reply to: Displaying string instead of input #4922
    1. Open Administrator.
    2. Open the Units table, and create your row, for example,
    Running; Not Running
    3. Create an input channel.
    4. Set the Format field to “Enum text”.
    5. Set the Unit field to your the unit you created on step 2.
    in reply to: Installation of Webstation plugins #4921
    First of all, upgrade Webstation to 5.0.7.0.
    in reply to: Rapid SCADA Documentation PDF #4914
    I hope in the future we will come up with something. Thank you for noticing.
    You can download zip archive from https://github.com/RapidScada/scada then find ScadaDoc folder and open web pages locally.
    in reply to: What is the meaning of the algorithm? #4913
    Please specify your question.
    in reply to: Installation of Webstation plugins #4912
    First of all, upgrade Webstation to 5.0.7.0 and Scheme Editor to 5.2.2.0.
    1. Please check ScadaWeb.log for errors.
    2. Horizontal or vertical depends on level width and height. Just resize it.
    3. Provide more details about the issue.
    4. Colorized gauge is the same component with background image. Background images can be found in the internet.
    in reply to: Rapid SCADA Documentation PDF #4908
    In Chrome press Ctrl+P, select “Save as PDF” printer and save it.
    in reply to: How to debug in Scada common server? #4907
    i can’t debug
    What do you mean in particular?
