Viewing 15 posts - 4,366 through 4,380 (of 6,278 total)
  • in reply to: Send data from server to Device Modbus #4972
    You need:
    1. Add commands in your Modbus template.
    2. Check that the commands work well in Communicator.
    3. Create output channels in Administrator to send commands from Server and Webstation.
    in reply to: Averaging formula #4969
    The new formulas for moving (rolling) averaging are shared here. Thanks a lot to Horacio for sponsorship.
    in reply to: Elastic Report and Chart Export function through iPad #4968
    However, I am unable to click on the select-box for the formats ‘Excel’, ‘PDF’, ‘HTML’.
    The old scripts may be cached. Can you clear browser cache on iPad?
    in reply to: Elastic Report and Chart Export function through iPad #4964
    replace the first line of the fragment to
    if (false && scada.utils.iOS())
    The features should be enabled on iPad. How do they work?
    in reply to: Elastic Report and Chart Export function through iPad #4963
    Let’s play with Elastic Report.
    Open C:\SCADA\ScadaWeb\plugins\ElasticReport\js\elasticrep.js
    Find the code:
        if (scada.utils.iOS()) {
            // disable Excel and PDF formats for iOS
            $("#rbHtmlFormat").prop("checked", true);
            $("#rbExcelFormat").prop("disabled", true);
            $("#divExcelFormat").addClass("disabled");
            $("#rbPdfFormat").prop("disabled", true);
            $("#divPdfFormat").addClass("disabled");
        } else {
            var format = localStorage.getItem(FORMAT_ITEM_NAME);
            // switch to stored format
            if (format == "PDF") {
                $("#rbPdfFormat").prop("checked", true);
            else if (format == "HTML") {
    in reply to: Elastic Report and Chart Export function through iPad #4962
    Replace the newly bought iPads with Android tablets?
    I would not like this way.
    Minute Data report are functioning normally on the iPad.
    This is interesting. My iPad can’t open Minute report. What application opens this report on your iPad?
    Is it due to the licensing of Elastic Report and Chart Pro which limits the function on iPad?
    Is there any way to enable these functions on the iPads?
    Only technical reason. The cause is that iPad has no internal location to save report files. May be this changed since the reports were developed. We should try to run them and see what happens.
    in reply to: SQL Server Compact 3.5 #4961
    Could you provide the info listed below?
    1. Sequence of steps that reproduces the problem.
    2. Expected result.
    3. Actual result
    in reply to: SQL Server Compact 3.5 #4958
    You should not use MSSQL Compact from SCADA-Server. If you need access to the configuration database from SCADA-Server, explore the files in DAT format from C:\SCADA\BaseDAT
    We will get rig of MSSQL Compact soon.
    in reply to: export data to MS SQL #4956
    Export to Database Module already included. It’s path is C:\SCADA\ScadaServer\Mod\ModDBExport.dll
    You need to add it to SCADA-Server on the Modules page and then configure using the scripts listed by this link.
    in reply to: When Scada Comm send data to Scada Server. #4953
    I hope you can change the size.
    For a big system, you may need our assistance to research how Rapid SCADA works under the required load and what the bottle necks are. Changing either data formats or internal protocol may be a subject of a contract between our companies. This is a business model of our project and many other open source projects.
    in reply to: Time Out #4949
    By default, it is in C:\SCADA\ScadaWeb\log\
    in reply to: When Scada Comm send data to Scada Server. #4948
    I need send tens of thousands of bytes to ScadaServer
    Could you describe your system?
    in reply to: When Scada Comm send data to Scada Server. #4947
    is already used900M memory
    Seems not usual. Do you use the default configuration?
    in reply to: Web Application on Windows Server 2012 R2 #4946
    You should create a new topic about export data to MS SQL. Read this before.
    in reply to: When Scada Comm send data to Scada Server. #4942
    when the cmdlen’s number more than 65536,the scada server can not receive the cmdlen
    Yes, this is a limitation.
    When debug ScadaServer,The computer is very stuck.Why?
    Depends on a computer hardware.
    ScadaComm runs long time,the memeory of ScadaComm become much bigger.Why?
    Can you provide memory usage chart?
    I think you can use Design Patterns to insteaed the switch method,the ProcCommCommand function is too long to beautiful.
    I agree. I hope this will be refactored in the future.
