Viewing 15 posts - 4,201 through 4,215 (of 6,279 total)
  • in reply to: Chart Pro graph header #5436
    In this year we plan to update Chart Pro. I hope we will include this feature.
    in reply to: Automatic Control Module: Copy&Paste triggers #5435
    Good idea. Thank you.
    in reply to: Can we use formulas on Raspberry Pi #5429
    I finished this point.
    Could you share how you did it?
    in reply to: Can we use formulas on Raspberry Pi #5425
    2.if I use automatic control and I set the time, assume I set output ON at 12.00AM and OFF at 12.05AM. Can It show that on the Web page. show something like I set the output ON at 12.00AM and OFF at 12.05AM.
    If you need to display time on web page, you should create input channels for storing time, set format to “Time”.
    Also create output channels that allows to set the input channels. Use the formula like SetVal(101, EncodeDate(Cmd)) for them. Where 101 is the input channel number.
    Also you need input channels that have value 0 or 1. These channels will be used as the triggers in Auto Control Module. And have to compare current time and predefine time.
    in reply to: Can we use formulas on Raspberry Pi #5424
    1.example. I got the data from registers modbus and I need to show on web page but the data that I got it has to convert to become a decimal number or it dose not real value. so can I use the formula to convert my data before I show it on web.
    What value do you get curretnly?
    What value do you need to display?
    in reply to: Chart Pro graph header #5423
    Hello Juan,
    Could you make a sketch?
    in reply to: Minimum Sampling Rate on Scada in Server room table #5416
    If you need to update chart plugin according to the custom requirements, we could discuss cost and deadline. In this case please contuct us by email and provide the detailed requirements.
    in reply to: Can we use formulas on Raspberry Pi #5415
    More details about the forumula needed.
    in reply to: Minimum Sampling Rate on Scada in Server room table #5411
    It can not detect my alarm condition immediately.
    You can, but it’s better to tick “Write events” and “Event on change” checkboxes of the input channel. And you will get events in case of alarms.
    in reply to: Modbus Edit table #5410
    Nice ))
    Use formulas to divide raw values.
    in reply to: Automatic control with Raspberry Pi #5406
    You should download the plugins and copy their files to your RPi.
    in reply to: Scheme Editor v5.2.3.0 can“t save changes #5405
    Thanks for noticing.
    Please take the editor from the new version. This bug was fixed there.
    in reply to: Modbus Edit table #5399
    Do step by step like described here and here.
    in reply to: New Rapid SCADA 5.7.0 Beta #5396
    This feature is going to be be implemented in a one of future versions, but not in this beta. If your company able to sponsor this feature, it can appear faster. In any case, I hope we will do it.
    in reply to: Restore the database #5393
    Unzip and copy *.sdf to C:\SCADA\BaseSDF\
    File name should be ScadaBase.sdf
    Also you need Communicatior configuration files that located in C:\SCADA\ScadaComm\Config
